Thread: audi q7 2007
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Post audi q7 2007
    Jun 2015
    london
    hi all
    I am new to the forum
    I was wondering if anyone would be able to help.
    Recently in the mornings I seem to be having trouble starting my car.
    it will crank for about 8-10 secs and then blow some white smoke from exhaust. An error message "EPS/ABS fault See owners manual" appears briefly before disappearing. There are no warning signs on car after it starts.
    for the rest of the day it will fire up first time. I have done a VCDS scan as below:
    Thursday,25,June,2015,18:18:08:33490
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0
    Data version: 20140905
    VIN: WAUZZZ4L68D002763 License Plate:
    Mileage: 51247mi Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
    55 56 61 62 67 6D 6F 72 76 77
    VIN: WAUZZZ4L68D002763 Mileage: 82450km/51232miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    67-Voice Control -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4L0 910 401 T HW: 4L0 907 401
    Component: 3.0L V6TDI G000AG 0010
    Revision: --H04--- Serial number:
    Coding: 0011775
    Shop #: WSC 31414 790 00001
    VCID: 3363699752B7BA8656F-8066
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
    Component: AL 750 6A 1000
    Revision: 00H64000 Serial number:
    Coding: 0000504
    VCID: 84017A4BC7994D3E3F5-80D1
    Address 03: ABS Brakes Labels: 4L0-910-517.clb
    Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
    Component: ESP ALLRAD MK25E1 0010
    Revision: 00H30001
    Coding: 0103569
    VCID: 295F8BFF807BF056EC3-807C
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 121
    Mileage: 82419 km
    Time Indication: 0
    Date: 2015.06.25
    Time: 07:57:53
    Freeze Frame:
    Count: 0
    Count: 2113
    Count: 128
    Count: 35072
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601100780879
    Coding: 0000147
    Shop #: WSC 00019 210 90927
    VCID: E3C359D722D7EA0666F-80B6
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H01 0053
    Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
    Part No SW: 4L1 910 732 G HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 386EU077544405
    Coding: 0002002
    VCID: 2E5578E3B995976E391-807B
    Subsystem 1 - Part No: 4L0 910 609
    Component: E0380 BedienteilH01 0060
    Subsystem 2 - Serial number: 00000000753074
    Subsystem 3 - Serial number: 0107.05.070000000100011055ˇ
    Subsystem 4 - Serial number: 011055ˇ
    Address 08: Auto HVAC Labels: None
    Part No SW: 4L0 910 043 HW: 4L0 820 043 F
    Component: KLIMABETAETIGUNGH05 0060
    Revision: 00---012 Serial number: 00000030045812
    Coding: 0001046
    VCID: E1CF53DF38CBF816743-80B4
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 82419 km
    Time Indication: 0
    Date: 2015.06.25
    Time: 07:57:57
    Freeze Frame:
    Voltage: 9.70 V
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0012121
    VCID: 316F639FA8AB8896243-8064
    Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AU716 H09 0080
    Coding: 00064792
    Shop #: WSC 31414
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150059
    Shop #: WSC 31414
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4L0 910 110 B HW: 4L0 035 110
    Component: MP3-Changer H43 0390
    Revision: 00043000 Serial number: AUZ5ZBG1063580
    Shop #: WSC 00000 000 00000
    VCID: 1E35A823C93507EE891-804B
    Address 15: Airbags Labels: 4L0-910-655.lbl
    Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
    Component: 71 AIRBAG AUDI8RH42 0230
    Revision: 03H42000 Serial number: 00399D031LY7
    Coding: 0014129
    Subsystem 1 - Serial number: 6332QSME312639717
    Subsystem 2 - Serial number: 6342QSME312629256
    Subsystem 3 - Serial number: 6352QSME312F773FU
    Subsystem 4 - Serial number: 6362QSME2F7C095B$
    Subsystem 5 - Serial number: 63734SME0D0654590
    Subsystem 6 - Serial number: 63834SME0D06517D4
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenks‰ulenmodul H08 0230
    Revision: 00H08000 Serial number: 90025071220637
    Coding: 0102142
    VCID: E6C540C3D1E59F2E811-80B3
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H02 0030
    Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4L0 920 981 B
    Component: KOMBIINSTR. M73 H21 0220
    Revision: 00600000 Serial number: 6EL530W57
    Coding: 3617458
    Shop #: WSC 44253 001 1048576
    VCID: 234399D7E2572A06A6F-8076
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 D
    Component: Heizgeraet H08 0080
    Revision: 0000000C Serial number: 00000009014264
    Coding: 0000001
    VCID: E0C956DB33C1F11E7BD-80B5
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B0751280E1
    Coding: F55BBE7F30720200
    Shop #: WSC 00551 210 91539
    VCID: 2D577FEFB493EC7600B-8078
    Address 34: Level Control Labels: None
    Part No SW: 4L0 910 553 C HW: 4L0 907 553
    Component: LUFTFDR.-CDC H03 7660
    Revision: --H03001 Serial number: 15.1528-0096.2
    Coding: 0015510
    Shop #: WSC 00551 210 91512
    VCID: 2A5D74F3857DFB4EE59-807F
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
    Component: MNS ECE H51 1060
    Revision: 00000000 Serial number: 399A1087598193
    Shop #: WSC 00508 210 59464
    VCID: 3B7341B77AE772C68EF-806E
    Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
    Component: TSG FA H12 0150
    Revision: 00000000 Serial number: Åsv
    Coding: 0002651
    VCID: 2F6B65E7BE9F9E66327-807A
    Address 46: Central Conv. Labels: None
    Part No SW: 4L5 910 289 C HW: 4I0 907 28< C
    Component: Komfjrtgera`t H02 0040
    Revision: 0040 -(- Serial number: 04043501720000
    Coding: 7610619
    Shop #: WSC 96950 788 00001
    VCID: 3567578F5CC3A4B678B-8060
    Address 47: Sound System Labels: 4L0-910-223-BO.lbl
    Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
    Component: DSP-High AU716 H03 0150
    Revision: PROD_01 Serial number: 00000000029069
    Coding: 0000023
    VCID: 28598EFB9B71C95EF3D-807D
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 E
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000046551
    Coding: 0011101
    VCID: DEB5682309B5C7EE491-808B
    Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
    Component: TSG BF H12 0150
    Revision: 00000000 Serial number: gu
    Coding: 0002651
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 F
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000008
    VCID: 3D774FAF64F37CF6B0B-8068
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 388E$077625709
    Coding: 0000001
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
    Component: TSG HL H21 0050
    Coding: 0002058
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H45 0630
    Revision: 00000000 Serial number: 00000704300314
    Shop #: WSC 12336 024 394758
    VCID: 3665508341C5AFAE711-8063
    Address 6D: Trunk Elect. Labels: None
    Part No SW: 4L0 910 945 HW: 4L0 827 851 B
    Component: ValeoHeckdeckel H21 0280
    Revision: --H21001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    VCID: ECD132EBCF09A57ED75-80B9
    Subsystem 1 - Part No: 4L0 910 946
    Subsystem 2 - Serial number: E5030100B
    Subsystem 3 - Serial number: RD25.05.07--H21001001B0076ˇ
    Subsystem 4 - Serial number: 1B0076ˇ
    Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
    Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
    Component: ILM HINTEN 2 H05 0060
    Revision: AAH05061 Serial number: 002776535-----
    Coding: 0003587
    VCID: 264580C39165DF2EC11-8073
    Subsystem 1 - Part No: 4L0 910 591
    Component: J_245_EE15_SKB09H10 0180
    Subsystem 2 - Part No: 4L0 910 591
    Component: J_394_EE15_SKB09H10 0180
    Subsystem 3 - Part No: 4L0 910 591
    Component: J_392_EE15_SKB09H10 0180
    Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
    Component: TSG HR H21 0050
    Coding: 0002058
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
    Component: Parkhilfe 8-Kan H12 0080
    Revision: 00H12000 Serial number: 06330712905191
    Coding: 0201146
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H16 1130
    Revision: 00000000 Serial number: 00000007669035
    Coding: 0010900
    VCID: 2C5172EB8F89E57E175-8079
  2. Re: audi q7 2007
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Your battery voltage looks like its dropping while cranking which is bringing in the ABS codes, how old is the battery? If its the original, likely it is struggling to hold charge overnight and give you low cranking speed and the slow start.
    There may be others along later who know more than me, but i'd look into the battery first, maybe check terminals are clean and secure as well.
    1 1 0
  3. Re: audi q7 2007
    Jun 2015
    london
    The battery was replaced by an independent garage just a few months ago. It was not the original Audi battery but a Bosch s5 one I think.
    I was thinking it could be the battery but obviously wasn't too sure. Could it be the battery is faulty or maybe not coded properly?
  4. Re: audi q7 2007
    Nov 2010
    104 Post(s)
    Sorry, don't know much about coding the battery. Worth getting in touch with the garage, battery should be warranted for 12 months maybe?
  5. Re: audi q7 2007
    Oct 2012
    United Kingdom
    12 Post(s)
    Glowplugs perhaps?
    Have you tried turning the ignition on for a few seconds then off then on again a few times then cranking?
  6. Re: audi q7 2007
    Jun 2015
    london
    I will give that a try in the morning. I've cleared all the faults and then will do another scan in the next few days. I'll post it here when I do.
    Also, going to visit the garage and show them my findings so far. Battery issue, glow plugs etc.
    Any other suggestions would be appreciated.
  7. Re: audi q7 2007
    Nov 2010
    104 Post(s)
    air in fuel if its reluctant in the morning but ok for the rest of the day.
  8. Re: audi q7 2007
    Jun 2015
    london
    I've tried the glow plug on-off method a few times but it made no difference. Car was just cranking and it finally started up after about 8 seconds. The cranking sounding like it was getting stronger as time lapsed.
    Anyhow, here is a scan I did this just now.
    Please have a look.
    Tuesday,30,June,2015,10:38:08:33490
    Mileage: 82590km-51319mi Repair Order:
    VIN: WAUZZZ4L68D002763 Mileage: 82590km/51319miles
    34-Level Control -- Status: Malfunction 0010
    Revision: 00H30001
    Coding: 0103569
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 96
    Mileage: 82572 km
    Time Indication: 0
    Date: 2015.06.30
    Time: 07:56:57
    Freeze Frame:
    Count: 0
    Count: 2113
    Count: 128
    Count: 33024
    Coding: 0001046
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 82572 km
    Time Indication: 0
    Date: 2015.06.30
    Time: 07:57:00
    Freeze Frame:
    Voltage: 9.70 V
    Coding: 0015510
    1 Fault Found:
    01577 - Turn-Off due to Over-Temp
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 82536 km
    Time Indication: 0
    Date: 2015.06.29
    Time: 08:08:34
    Freeze Frame:
    Error Code: 68
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4L0 910 181 A HW: 4L0 915 181
    Component: J0644 BEM H12 0690
    Revision: -------- Serial number: 00000000001290
    VCID: 254787CFEC63D436C8B-8070
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 0802191134
    Coding: 344630393135313035442056413030383032313931313334
    1 Fault Found:
    02256 - Quiescent Current
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 136
    Mileage: 82533 km
    Time Indication: 0
    Date: 2015.06.28
    Time: 23:09:36
  9. Re: audi q7 2007
    Jun 2015
    london
    Just to update...
    Spoke to garage over the phone (who fitted the battery). They will contact the company for battery issue and get back to me.
    I realize that the cranking problem happens in the morning (after the car has been left standing overnight) so I decided to give it a start at 3am in the morning to see if there were any problems (I had last driven it about 8pm that evening). It started with no problems. Then when I left to go to work again at 8am (when I would usually expect the cranking problem) it started fine.
    So it seems the problem happens after a long standby.
    As for the air in fuel - that sounds depressing already!
    I will go into the garage when they want to take my battery out to send back and tell them the symptoms.
  10. Re: audi q7 2007
    May 2008
    darlington
    I have the exact same fault.
    I beleive it is the starter motor as fault.
  1. Please Help 2007 Audi A6 Allroad
    By NickNock in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-12-2014, 11:17 PM
  2. 2007 Audi A6 2.7 TDI
    By GC2012 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-12-2013, 08:28 PM
  3. Please Help audi a4 3.2 quattro 2007
    By j c in forum New Member Introductions
    Last Post: 21-10-2011, 09:27 AM
  4. Question 2007 Audi A4 1.8T S
    By Sheridan_j in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-01-2011, 04:32 PM
  5. 2007 Audi A6 2.7 TDi
    By Del Boy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-07-2010, 04:35 PM
