Thread: N75 valve issue
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. N75 valve issue
    May 2015
    Loch Lomond, Scotland
    Can anyone tell me or show me which hose goes where on the N75. I have a feeling someone messed with it and messed up the vacuum hoses position.
    I also run a test using VCDS Lite and the N75 duty cycle stays at 15% no matter what revs
  2. Re: N75 valve issue
    May 2015
    I have inserted a few pictures. 1 of the VCscope mostly at idle but also revved up as you can see.
    A pic of the N75 with hoses attached as follows
    RED - to EGR
    GREEN - to turbo
    YELLOW - to the outside world
    BLUE - Disappears into passenger side wing
    Is this the right setup?
    Next picture:
    A hose with a screw in it???
    Any help on all these would be much appreciated
  3. Re: N75 valve issue
    Aug 2011
    Meath
    Do you have a vacuum reservoir? Black plastic ball about the size of a cricket ball? That's maybe where the blanked hose went to
  4. Re: N75 valve issue
    May 2015
    Haven't spotted a vacuum reservoir anywhere.
  5. Re: N75 valve issue
    Nov 2010
    halkirk caithness
    try passenger side front wing behind wheel arch cover
  6. Re: N75 valve issue
    May 2015
    okay, but why would the other end have a screw in it?
  7. Re: N75 valve issue
    Nov 2010
    halkirk caithness
    to keep a vacuum check audi part num 443131541
  8. Re: N75 valve issue
    Oct 2014
    TAUNTON . SOMERSET
    I think egr is blanked thats is easy way disconect egr vacuum line and put the screw so u lose no vaccum and egr is not opening. Check or egr have vaccum line attached??
  9. Re: N75 valve issue
    May 2015
    EGR has the vacuum line attached.
    There is good vacuum from the line that goes into the N75, there is just no vacuum from the lines that come out and run to the wastegate actuator and the EGR. The grey plug on the N75 gives 12V from the red/white wire when ignition is on.
    When I put the vacuum line that goes into the N75 directly on the actuator, the lever moves up in a nice and smooth motion.
    So either I have a vacuum leak somewhere ( I have tried several times to find this without success) or the N75 is faulty ( I have opened up both valves and everything inside moves freely) but seeing the other codes it could also be a short in the wiring loom or a faulty ECU.
    Think I should call out an auto electrician.........
  10. Re: N75 valve issue
    Oct 2014
    TAUNTON . SOMERSET
    That car you have? And that fault codes
  1. N75 valve
    By darthweasel in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-12-2012, 10:52 AM
  2. N75 Boost Valve Issue A6
    By bag320 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-10-2011, 01:33 PM
  3. N75 Race Valve J versus H valve.
    By comfortablynumb in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2009, 12:33 PM
  4. n75 valve
    By mygolfygti in forum Golf MK4 - 1999 - 2004
    Last Post: 25-03-2009, 07:37 PM
  5. Please Help My new n75 valve is different
    By audiyoudo in forum Audi A3 - Archive Topics
    Last Post: 26-07-2008, 09:26 AM
