Thread: Duel mass vs solid flywheel
Results 1 to 10 of 15
  1. Duel mass vs solid flywheel
    Dec 2012
    Ipswich
    Hi all my flywheel has just given up just wondering if it's worth paying the extra for duel mass or convert to the solid one anyone done this or have a price on the replacement
    Audi A4 2.0tdi 140
  2. Re: Duel mass vs solid flywheel
    Apr 2015
    Damascus, Syria
    If it was me, I would keep it as original specs.....DMF replaced with DMF, and live with it. I have heard of some gearboxes having a problem after the DMF was replaced with a solid Flywheel, but this is not to say that solid flywheel was the cause... could have been co-incidence. But I am sure that some one here will have personal experience of it, and enlighten us.
  3. Re: Duel mass vs solid flywheel
    Dec 2012
    Ipswich
    To be honest I was thinking the same sticking with the dmf it's got to be there for a reason however bad the design is
  4. Re: Duel mass vs solid flywheel
    Aug 2011
    Meath
    It's not really a bad design, it makes the car smoother to drive and the clutch is lighter. say it costs £1000.00 and lasts 100,000 miles thats penny a mile. Not bad considering you can ruin the 2.5k gearbox with a solid flywheel
  5. Re: Duel mass vs solid flywheel
    Dec 2012
    Ipswich
    My mates dmf died with 26k and my brothers at 34k I've only heard of people having trouble with them
  6. Re: Duel mass vs solid flywheel
    Aug 2011
    Meath
    They normally last a lot longer than that. look on the interweb for darkside developments they sell all the kit for SMF. I was going to put a solid flywheel on my car Skoda wanted 600 for the flywheel, the DMF kit was 2/3 of that
  7. Re: Duel mass vs solid flywheel
    Dec 2012
    Ipswich
    That's expensive for a solid there only £350 is on fleabay
  8. Re: Duel mass vs solid flywheel
    Aug 2011
    Meath
    You can get a G60 flywheel off an ALH Caddy for 20 squids in a scrappy but there's other issues. Gearbox noise is one. The SMF is thinner so there's more pedal travel on the clutch. If you are a racy type the take-up is very rapid and the driving can feel harsh. BTW my prices are in yoyos or Euros
  9. Re: Duel mass vs solid flywheel
    Dec 2012
    Ipswich
    Flywheel done went for a dmf in the end and new clutch kit seemed silly not too all in £605 and got to say the car runs super smooth even on idle where it used to have a lump every now and then thanks all for your advice
    1 2 0
  10. Re: Duel mass vs solid flywheel
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    If I was planning to tow a caravan, I'd choose a solid flywheel. The DMF type can overheat quite easily as it does not have the heavy mass to absorb the heat.
    The DMF is kinder to the transmission if the driver is a bit rough with take up / gear changes but for reliability the solid type wins hands down. What did we do before DMFs were available ? A lot of DMF failures are due to overheating due to clutch slipping at traffic stops. A lot of drivers do not use the handbrake as intended ( they can't all be automatics !).
    Skoda Octavia II SE 1.9PD TDI
  1. duel mass flywheel or solid replacement
    By Brendan Mills in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 19-10-2012, 12:32 PM
  2. Question Duel mass flywheel????
    By Stevebt in forum Golf MK4 - 1999 - 2004
    Last Post: 04-11-2009, 01:12 AM
  3. T4 Duel Mass Flywheel.
    By Brian Considine in forum The Commercial Range
    Last Post: 24-10-2009, 07:04 PM
  4. Duel mass flywheel
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2008, 08:30 PM
  5. lt35 duel mass flywheel
    By 0141flyingv in forum The Commercial Range
    Last Post: 20-10-2008, 11:04 AM
