Thread: Noob VCDS owner with Wheel Speed Sensor Problem on Passat B6
Results 1 to 8 of 8
  1. (solved) Noob VCDS owner with TPMS Problem on Passat B6
    Feb 2014
    Swansea, uk
    Hi guys, had a fault on my passat b6 (2008 uk model) saying my tyre pressure sensor is faulty.
    I've finally bit the bullet and got my VCDS and ran a scan this morning. I was hoping it would be more specific as to which of the wheel speed sensors were at fault so I can order the right one instead of trial and error.
    Please note that this model car collects the tyre pressure from the ABS wheel speed sensor and not from a module inside the wheel.
    It may even be on the read out but i'm not very familiar with it. Perhaps someone will be able to point out what I missed?
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
    Component: J104 C4 440 V2 0003
    Revision: --020--- Serial number: 00000776095882
    Coding: 0003339
    Shop #: WSC 05311 000 00000
    VCID: 1F4DDF0FCEA074D9775-804A
    1 Fault Found:
    02214 - Tire Pressure Warning
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 137
    Mileage: 312291 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:30:16
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 12.00 V
    Bin. Bits: 00011111
    Count: 203
  2. Re: Noob VCDS owner with Wheel Speed Sensor Problem on Passat B6
    May 2007
    17 Post(s)
    Have you reset the system via the dash button?
    If one of your wheel speed sensors was faulty, that would be what the trouble code would say.
    Jim.
  3. Re: Noob VCDS owner with Wheel Speed Sensor Problem on Passat B6
    Feb 2014
    Swansea, uk
    Yes Jim, I even went as far as as holding it down for a minute but it did absolutely nothing.
    it used to work until 2 years ago (yeah I know, let it slide) then it was on a few weeks before a tyre change and I never reset it then after the tyre change I made sure they were all set the same but it wouldn't reset.
    I believe I have the indirect TPMS so no sensors in the wheels themselves but thinking, if there was a fault with the wheel speed sensor then surely the abs light would be on.
  4. Re: Noob VCDS owner with Wheel Speed Sensor Problem on Passat B6
    May 2007
    17 Post(s)
    Quote Originally Posted by dewitts View Post
    Yes, your right. I've had one on a Polo that wouldn't reset because the switch itself was faulty. I'm sure there will be a measured value you can check with VCDS that will let you see if the switch is sending the reset signal to the ECM.
  5. Re: Noob VCDS owner with Wheel Speed Sensor Problem on Passat B6
    Feb 2014
    Swansea, uk
    I found a retrofit post last night which was tested by turning on the feature then resetting it via VCDS but then if that was the case perhaps the fault wouldn't be present?
  6. Re: Noob VCDS owner with Wheel Speed Sensor Problem on Passat B6
    May 2007
    17 Post(s)
    Yeah, I think I've seen that somewhere too, now that you mention it.
    Well, you already have the system so you can skip the turn it on bit. Just try the reset via basic settings in the ABS ECM.
  7. Re: Noob VCDS owner with Wheel Speed Sensor Problem on Passat B6
    Feb 2014
    Swansea, uk
    Well I managed to find the TPMS controller and do a reset, the fault has cleared, I got the chime and when I pressed the TPMS button too so I guess i'll find out whether it's resolved tomorrow when I go to work.
    Finger, toes, eyes, legs and pubes crossed! lol
  8. TPMS Fault (solved)
    Feb 2014
    Swansea, uk
    After managing to find the TPMS module under brakes and doing a reset via VCDS I have managed to clear the fault and all 'appears' to be working fine now.
    Going to get my car up on ramps tomorrow and see if I can find the damn earthing problem which is stopping my Parking sensors working.
  1. Noob Passat B6 Wagon owner :)
    By Cannondave in forum New Member Introductions
    Last Post: 31-07-2014, 06:27 PM
  2. Wheel speed sensor replacement
    By BluestarT25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-09-2013, 10:28 AM
  3. Fault 00287 - ABS Wheel Speed Sensor: Rear Right
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2013, 08:13 AM
  4. TT Wheel speed sensor
    By nickgtn in forum VCDS - General Questions
    Last Post: 09-09-2008, 01:12 PM
  5. ABS - wheel speed sensor (s3)
    By Jon_Halibut in forum Audi A3 - Archive Topics
    Last Post: 15-06-2007, 03:08 PM
