Thread: Rubbing noise when turning right
Results 1 to 9 of 9
  1. Rubbing noise when turning right
    Feb 2010
    Cambridge
    So I've had the car a few weeks and have a few niggles
    Revs pulse if i lift off the throttle and coast for a while
    Rear tyres are very noisy (uniroyal rainsport 2)
    and just recently I've noticed a rubbing noise when turning right. This morning I kept the steering angle the same and as the wheel rotated you could hear it rub at a certain point. The tyre size is correct and I can't see anything on them, could a wheel bearing cause a rubbing noise?
    A6 3.0 TDI Le Mans
  2. Re: Rubbing noise when turning right
    Dec 2007
    8 Post(s)
    It may just be noise from cv rubber on full lock.
  3. Re: Rubbing noise when turning right
    Feb 2010
    Cambridge
    Thanks but its not when the car is on full lock
    A6 3.0 TDI Le Mans
  4. Re: Rubbing noise when turning right
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    Wheel bearings usually a constant whine / grumble when loaded rather than associated with a particular wheel orientation / pulsing sound. Otherwise a lot of grovelling needed to see if the tyres are developing a fault / bulge on the inner sidewall or if a bit of wheel arch lining isn't properly located. Plastic bags trapped on the front suspension is always good for strange noises. Stone trapped on edge of brake pad?
  5. Re: Rubbing noise when turning right
    Feb 2010
    Cambridge
    Cheers, if its only doing it when turning right would that indicate the left side is where I should look first?
    I'll jack the car up at the weekend and take a look.
    A6 3.0 TDI Le Mans
  6. Re: Rubbing noise when turning right
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    Not necessarily. After all, in your example, the rear of the right tyre / wheel has moved towards the arch linings, while on the left the front of the tyre / wheel has moved towards the arch linings. Don't forget the axle / body stands if any part of your body is underneath. Raising the car in the air also drops the wheel / suspension relative to the body so start looking while it's on the ground.
  7. Re: Rubbing noise when turning right
    Sep 2008
    mostly in the garage
    Quote Originally Posted by Chriseybaby View Post
    Absolutely it can. A wheel bearing can be quiet in a straight line but rumble when loaded as in a turn.
    ie a worn bearing on the left will rumble in a right turn and vice versa.
    1 2 0
  8. Re: Rubbing noise when turning right
    Feb 2010
    Cambridge
    I took a look under the car last night and there are no signs of rubbing. I did notice that a bit of the under tray is hanging off in the middle but I can't see how that could be causing any issues. I didn't have any axle stands so didn't fancy getting underneath to fix it back on.
    A6 3.0 TDI Le Mans
  9. Re: Rubbing noise when turning right
    Feb 2010
    Cambridge
    For a bit of closure on this....
    I noticed that the noise when away if I lightly touched the brakes. So, after a bit of reading, I decide to do a few heavy braking events (obviously when nobody was behind). I went from 65 down to 30 ish quite hard and now the rubbing noise seems to have gone away.
    A6 3.0 TDI Le Mans
  1. Question Grinding / rubbing noise when turning slowly at near full lock
    By rp200 in forum Jetta MK3 - 2005 - 2013
    Last Post: 28-10-2013, 11:10 AM
  2. Question Creaking/rubbing noise from front o/s
    By albion80 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-03-2012, 11:31 PM
  3. mk3 rubbing noise
    By Golf tdi Hal in forum Golf MK3 - 1993 - 1999
    Last Post: 07-05-2010, 07:03 PM
  4. rubbing noise n/s front
    By sweeper in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-07-2008, 10:09 PM
  5. Rubbing, grinding noise when turning left
    By trousdala in forum Golf MK4 - 1999 - 2004
    Last Post: 18-05-2008, 09:24 PM
