Thread: Wind noise a6
  1. Wind noise a6
    Sep 2008
    Hi all
    I have test driven about 7 A6's recently from 2012 - 2014 plates. To various degrees there is wind noise. In my present 62 plate I use a strip of newpaper and close the door, in most places on all doors it can be pulled out with little force.
    If you look at the doors, the rubber seals do not come out a lot compared to the hard surface of the door edges, so the seals do not get squashed when the door closes. In my 2006 2.7 TDi if someone talks close to by driver door I cannot here what the are saying, now I can.
    It seems Audi has gone backwards.
    regards
    krish
    Any views?
  2. Re: Wind noise a6
    Mar 2014
    United Kingdom
    33 Post(s)
    Wind noise is often cited for the A6 C7, it would appear. The FL cars have double glazing as standard and it is whisper quiet in the cabin - eerily so, in fact. I do wonder if the decision to fit double glazing as standard was because of the frequent complaints about wind noise.
  3. Re: Wind noise a6
    Mar 2013
    Northwest
    7 Post(s)
    I see that the introduction of acoustic glazing for the windscreen and front windows seems only to apply to the standard saloon and avant and not the Allroad. Does anyone know if that is correct?
    Audi A6 Allroad 245 in Dakota Grey (2013)
    Audi SQ5 (C+S) in Ultra Blue (2022)
    Yamaha DT400E in Competition Yellow (1977)
  4. Re: Wind noise a6
    Aug 2014
    Shrewsbury, Shropshire, England
    Hi Kris
    Must admit I feel the same. We have a 2012 Avant and when I test drove it we didn't really do any big speed. Now after 6 months I must admit for a "prestige" car the wind noise is
    a bit poor. Never mind, ride quality makes up for it............oh I forgot to say our last car was a Fiesta ST, I suppose a ride on lawn mower has a better ride quality
    Andy
  5. Re: Wind noise a6
    Sep 2008
    Hi andy
    lol fesita!! Big upgrade foe you then. I have had one type for the last 15 years. A6....... The engine noise of this one is the lowest. Sadly the door seals and i think the general weight reduction and CO2 rating have produced a fiesta in sheeps clothing.
  6. Re: Wind noise a6
    Sep 2008
    Wind noise reduced.
    The door seals are ok, not great, if you try a 1 inch strip of newpaper (8 inches long) and close the door, while there is some grip it does come out quite maybe a force of pulling 200-300 gms of weight.
    The glass seals are poor, for one the window goes the outer rubber about 3 to 4 mm. and the inner rubber is providing no force against the inner side of the window glass. I added about 5 layers of insulation tape over the whole upper side sloping down the the front of the door and the side going down to the bottom of the window. This provided enough grip when the window was up and I could not stick a medicine plastic strip as I did
    before. While there is wind noise, it is not any more concentrated around the top of the driver door. I think Audi I have to upgrade all its cars with better window beading.
    krish
  1. Wind noise
    By goldenwonder in forum Polo - Derby - Lupo - Fox
    Last Post: 31-10-2011, 03:15 PM
  2. Wind noise
    By theoc in forum Passat CC
    Last Post: 25-05-2010, 06:12 PM
  3. Question wind noise
    By rollapig in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-07-2009, 10:24 PM
  4. Wind Noise
    By jkh112 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-06-2009, 09:22 PM
  5. Wind Noise
    By Astonm in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-07-2008, 05:26 PM
