Thread: 2.0 tdi caga engine code
  1. 2.0 tdi caga engine code
    Nov 2013
    mandfield woodhouse
    Just noticed this when in 2nd gear when the revs pass say 3k there seems to be a higher pitched noise coming from the engine can hear it comes then goes away.
    Went to see if it would do it in neutral while on the drive and it wouldn't rev passed say 2.5k
  2. Re: 2.0 tdi caga engine code
    Nov 2013
    mandfield woodhouse
    Turned esp off and it does rev passed 2.5 from a stand still now.
    As for the slight high pitch noise on hard acceleration in 2nd ill monitor that
  3. Re: 2.0 tdi caga engine code
    Pembrokeshire
    22 Post(s)
    high pitched noise, could be a boost leak ?
  4. Re: 2.0 tdi caga engine code
    Nov 2013
    mandfield woodhouse
    Hope it is a boost leak it's very slight can't hear it when window is down.
    Only hear it under hard acceleration in 2nd maybe 1st as well
  5. Re: 2.0 tdi caga engine code
    Nov 2013
    mandfield woodhouse
    This noise isn't just in 2nd gear I think it's a normal noise can only be heard very slightly with radio off and windows up very faint when window is down or radio is on you can't hear it. Only hear it when accelerating hard with the gears passed 3,000 revs
  1. Seat exeo 2.0 tdi caga 6 speed box
    By rchads89 in forum 2.0TDi - Engine
    Last Post: 25-10-2015, 10:55 AM
  2. Access code for engine control unit...A4 '10' chassis 8K 2.0L TFSI engine code CDNCAs
    By baylissboy in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 18-02-2015, 10:17 PM
  3. Audi A4 B8 2.0 TDI CAGA - DPF Problems.
    By A11an in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2012, 08:15 PM
  4. Please Help Ecu Engine a4 2.0tdi CAGA
    By pittyxp in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-08-2012, 05:43 PM
  5. Question Replace injector loom in 2002 Golf TDi -ATD Engine Code - PD Engine ?
    By Negger in forum Golf MK4 - 1999 - 2004
    Last Post: 03-06-2011, 11:26 AM
