Thread: Alarm keeps going off!
  1. Alarm keeps going off!
    Jan 2015
    Nottingham
    I've Googled this and can't seem to find a model specific solution for an Avant B8 and I am pulling my hair out. (and no doubt my neighbours too)
    The alarm keeps sounding when locked it can be 2 mins after locking or 2hrs very random sounding off.
    This why I'm typing this now as I have just spent a good 1hr trying to find how to stop it.
    Is there some way of disconnecting temporarily until I can get to a garage or a way of fixing myself?
    I'm aware of the batteries wearing out can anybody tell me where to find the bloody thing as I've checked in the boot behind the right side removable cover and cannot see anything that resembles an alarm!?
    Desperate help please!
  2. Re: Alarm keeps going off!
    46 Post(s)
    You need a fault code scan done with VCDS as some generic readers won't pick up on manufacturer specific codes.
    I'd be disconnecting the negative terminal on the main battery for now.
  3. Re: Alarm keeps going off!
    Nov 2013
    Cumbria
    Quote Originally Posted by Ferris_uk View Post
    Try the fuses on the left hand side of the dash and pull the instrument cluster fuse - the immobiliser is built into it. If your alarm stops going off it's most likely an immobiliser fault.
    Audi A6 C7 Avant - quattro, black edition sline - 3.0 BiTDi
    Audi A3 8PA - quattro, black edition sline - 2.0T
    Audi A4 B8 Avant SLine - 3.2 V6 Quattro - now sold
    Audi A3 8P - 2.0T Quattro - sold
    Audi A4 B7 Avant - 2.0T - heap of junk, now gone!
  4. Re: Alarm keeps going off!
    Jul 2008
    Essex, United Kingdom
    Hi, Just a couple of tips that hopefully will be useful.....
    1. Do you have an air freshener in the car? Sounds silly but I have one that hangs off the rear view mirror and when it moves it sets the alarm off. If you've got one, try removing it.
    2. On the inside right of the drivers side door you can turn off the interior and tow protection alarm for the car. Its two buttons - you'll need to press these every time you lock the car, but if you do this and find that the alarm stops going off, chances are its a fault with the interior alarm system.
    3. Finally - try closing the air vents. Sometimes air blowing in can set off the interior alarm.
    Ultimately its probably going to be a case of doing a fault scan to look for any faulty sensors or wiring. Hopefully the above might help a bit in the meantime!
    Regards
    -Andrew
    p.s. Chris - you suggested disconnecting the battery terminal. Are you sure thats going to help? Its commonplace for even el-cheapo aftermarket alarms to have a backup battery that recharges....
    1994 VW Polo 1.4L (Scrapped)
    1998 VW Polo 1.4L - Somewhere Out there...
    2004 Audi A4 1.9TD 130bhp <--Gone but not forgotten!
    2011 Audi A4 3.0 V6 TDi 240bhp - Moved on, but still going
    2017 Audi S3 2.0 TFSI 310bhp
  5. Re: Alarm keeps going off!
    May 2007
    17 Post(s)
    The alarm records what circuit/sensor caused the last 4 trigger events. It's stored in one of the measured values in the Covenience ECU. A code scan probably wont show a fault but a read of the measured values will tell you what's setting it off.
    Regards.
    Jim.
  6. Re: Alarm keeps going off!
    Apr 2015
    limerick, Ireland
    I have had the same problem with my A6 2ltrD sline.. 2012.. I had codes showing the fuel cap actuator as the problem, which I replaced.. quite cheap €28.00 part. The next issue is the alarm horn, passengers side front bulk head... replaced that also.. much more expensive €210.00 and that didn't fix it either.. Going to get the car tested by someone in town..audi dealer here is useless... I did note the amount in stores in UK over 220 units on the shelf...may be a issue then.. with the sounders..
    Hope this helps..
    Will try and post back here when I get the codes...
    Yak
  1. Please Help Golf alarm fault how to disarm the alarm to lock car
    By Ped87 in forum Golf MK6 - 2009 - 2013
    Last Post: 07-12-2014, 01:09 PM
  2. Question SPAL Alarm - indicators not blinking when turning alarm on/off
    By xuerebx in forum Vehicle Security - Retrofit / aftermarket alarms & immobilisers
    Last Post: 06-08-2014, 10:41 AM
  3. Burnt out alarm module? disable alarm?
    By Rob69 in forum Touran - Sharan - Caravelle
    Last Post: 29-06-2013, 07:48 AM
  4. Is my alarm unit failing, or alarm being triggered?! Help
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-07-2010, 04:30 PM
  5. A4 Alarm
    By statman in forum Audi A4 - Archive Topics
    Last Post: 27-09-2007, 01:19 PM
