Thread: 2005 A4 2.5tdi V6 starting issue hot and cold
  1. Exclamation 2005 A4 2.5tdi V6 starting issue hot and cold
    Feb 2011
    N.Ireland
    Hi I am hoping for some advice/help. I have owned my 2005 A4 2.5tdi auto for the past 4 years. It now has 98K miles and has developed a starting issue. It doesn't matter whether the engine is hot or cold, it wont start although if you spray a small amount of easy start, it will spring into life and run with no issues at all for as long as you want to drive it. If the car is switched off and left for a few minutes, it will start no problem. If left off for more than 20 minutes it wont start unless you use easy start and then runs great when started.
    I have scanned the car with VCDS and there is no codes stored. There is no air in the clear fuel line at the engine. Today I tired starting the car with live data active focusing on engine speed G28 which showed 0rpm during cranking.
    This issue original started when weather cold and would take longer to start when cold but always started (no issue when warm), I thought this was glow plugs and was planning to replace although over a few weeks it developed into a cold / hot starting issue.
    Can anyone shed any help or advice on this? Any help greatly appreciated
  2. Re: 2005 A4 2.5tdi V6 starting issue hot and cold
    Jun 2006
    UK, Mids
    Diesel injector pump is the weakest link. It may just be an internal sensor. You can get the pump tested at diesel bob's.
    Audi A8 - 2015 - 3.0TDI
  3. Re: 2005 A4 2.5tdi V6 starting issue hot and cold
    Feb 2011
    N.Ireland
    Thanks for the reply. I was out in the car yesterday, run great for 10 mile then when coming to a junction she started to lose power, after 1/2 mile she died and has refused to restart. After getting it towed home I scanned it again with VCDS.
    2 Faults Found:
    17583 - Pre-Injection Turned Off
    P1175 - 35-10 - - Intermittent
    00550 - Start of Injection Regulation
    11-10 - Control Limit Not Reached - Intermittent
    Readiness: 0 0 X X X
    Any advice greatly appreciated
  1. Question Passat B6 2.0 TDI hot starting issue
    By freebird69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-01-2018, 08:08 AM
  2. a4 2.5tdi v6 poor hot starting
    By boratdi130 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-09-2009, 09:43 PM
  3. Please Help 2005 TDI Hot Starting Fault
    By nixamus in forum Golf MK5 - 2004 - 2009
    Last Post: 09-02-2009, 10:28 AM
  4. Hot starting issue
    By orangejohn in forum Chat - Anything with wheels
    Last Post: 05-09-2008, 11:00 PM
  5. Greetings All & hot starting issue
    By orangejohn in forum New Member Introductions
    Last Post: 02-09-2008, 09:31 PM
