Thread: a4 b8 throttle body replaced tdi 2.0 - now another issue p2015 - inlet manifold or ?
  1. a4 b8 throttle body replaced tdi 2.0 - now another issue p2015 - inlet manifold or ?
    Aug 2011
    Surrey
    Hi got diags run on car throttle body needed replacing. So swapped out . same
    light re appeared on dash twice even after replacing. Car has 160000 FSH
    no loss of power everything ok.
    New fault code - 7859-p2015 intake manifold flap position sensor (bank 1) implausible signal
    -mechanical failure.
    https://www.vwaudiforum.co.uk/forum/showthread.php/... -
    This is exactly what's happened to me, the fix for this guy is unknown - the part marked blue in the post I believe is what has been replaced on my car -
    throttle body.
    Car has been serviced regularly and drives fine, and only other "history" to car is that it has had egr sensor replaced (I think) 20,000
    miles ago and a forced dpf regen - 20,000 miles ago.
    They have used a 3rd party throttle body from euro car parts but it's the same brand that audi use - vdo/siemens.
    They also said they found excessive build up on intake manifold flap - "may require new intake flap or intake manifold" was their
    comment
    Further searching on another forum brings up this
    Which would suggest I may need a new intake manifold.
    or..
    http://www.audizine.com/forum/showthread.php/54267...
    "The main problem is that the arm controlling the flap starts to jam hence the fault reading." - forgive my ignorance but I don't know which part is being cleaned
    here - apologies.
    The question I ask which I appreciate maybe difficult to answer is would it be likely that only 1 of the parts was
    originally faulty, or would both parts (throttle body & intake manifold) of "gone" wrong at the same time.
    Many thanks for any info.
    Mike
  2. Re: a4 b8 throttle body replaced tdi 2.0 - now another issue p2015 - inlet manifold or ?
    Aug 2011
    Surrey
    I think the exact answer to my problem is intake manifold flap.
    After having time to re-read all other posts and not being a mechanic my error code is identical to this
    error code - 7859 - Intake Manifold Flap Position Sensor (Bank 1) .
    I will try and get the fix applied, but I am still curious as to whether a whole new throttle body was originally required.
    Thoughts anyone?
  1. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  2. 'Setting up' the new inlet manifold throttle body
    By bob b in forum Golf MK5 - 2004 - 2009
    Last Post: 11-01-2013, 11:18 AM
  3. Inlet manifold V6 TDI
    By hbsteer in forum Touareg
    Last Post: 03-03-2011, 07:13 PM
  4. neuspeed throttle body and inlet for sale
    By danvisteon in forum Golf MK1 - 1974 -1984
    Last Post: 18-02-2009, 01:06 PM
  5. Replaced throttle body
    By Debsbp in forum Golf MK3 - 1993 - 1999
    Last Post: 01-03-2008, 01:27 PM
