Thread: Radio antenna 1 cable or 2?
  1. Radio antenna 1 cable or 2?
    Feb 2015
    Sheffield uk
    Hey guys,
    Long story short, had the mk6 3 weeks, it can with an aftermarket double din.
    It's got an antenna converter, that I had to wire into 12v to get the booster working.
    But there is only one antenna cable in the car, that I can see.
    From all other posts I've read there should be 2 cables.
    Has the previous owner removed the dab antenna if It had one/can be done?
    Fm is working ok now it's wired in.
  2. Re: Radio antenna 1 cable or 2?
    46 Post(s)
    the stock fm radio antenna should have a white plug with 2 cables going into it (see below)
  3. Re: Radio antenna 1 cable or 2?
    Feb 2015
    Sheffield uk
    Thanks for the reply Chris.
    It looks like they've taken one of the cables out of the white plug and wired an adaptor into it.
    Anyone know if it's possible to remove the whole dab antenna(if it had it) and wiring or is it more likely that they've hidden it in the dash?
    I'm going to have a dig tomorrow down the back. So far I've not felt anything and I've followed it a fair way back.
  4. Re: Radio antenna 1 cable or 2?
    Feb 2015
    Sheffield uk
    This is what's behind mine. I've tried to trace it back as far as I can but it disappears into the dash.
  5. Re: Radio antenna 1 cable or 2?
    Feb 2015
    Sheffield uk
  6. Re: Radio antenna 1 cable or 2?
    May 2008
    London, UK
    If it originally had the RCD 210 from the factory (i.e. pre-2012 S or Bluemotion models without DAB) then yes that single connector would have been fitted from the factory.
    The dual connector in Chris' picture was only supplied in cars with the RCD 310 or upgraded head units.
  7. Re: Radio antenna 1 cable or 2?
    Feb 2015
    Sheffield uk
    Ahr thanks J400uk that's a good answer and it makes sense.
    I ran the codes out of the service book sticker through the decoder and one of them came through as the Radio, when googling that code on its own it shows as rcd 210.
    Guys thanks very much for your help. Muchly appreciated.
  1. Question Diversity Radio Antenna
    By Mike'A in forum Jetta MK3 - 2005 - 2013
    Last Post: 16-01-2012, 08:25 PM
  2. Question Replacement Antenna cable with Fakra conectors needed
    By karmann in forum In Car Entertainment
    Last Post: 27-06-2011, 04:51 PM
  3. Question Two radio antenna cables.
    By geirkh in forum Golf MK5 - 2004 - 2009
    Last Post: 05-09-2010, 10:23 AM
  4. Mk3 Golf antenna cable
    By approvedlunatic in forum In Car Entertainment
    Last Post: 27-02-2010, 01:39 PM
  5. Question Radio Antenna
    By mkc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-05-2008, 06:08 PM
