Thread: Recommended tyre pressures 245-45/18
Results 11 to 20 of 37
  1. Re: Recommended tyre pressures 245-45/18
    Jan 2010
    Yate UK
    17 Post(s)
    I don't think it's a Conti problem per se, I am running Contis on the front at the pressure recommended by the sticker and had no uneven wear issues.
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
  2. Re: Recommended tyre pressures 245-45/18
    Jun 2011
    Drogheda Ireland
    I checked the label on the drivers door and its showing 32psi.
    I fitted the Goodyear F1's today and moved the Conti's to the rear. The Bridgestone that came off the car where wearing slightly on the outside shoulder on both sides...
    Carried a 4 wheel laser alignment on the car after fitting the new tyres and the geometry was all within spec. Decided to run the F1's at 29psi and see how the wear goes.
    P.S There is so much more grip with the F1's compared to the Conti Sport Contact 5
    VW CC GT 177 DSG
  3. Re: Recommended tyre pressures 245-45/18
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    What's noise and comfort like with those?
  4. Re: Recommended tyre pressures 245-45/18
    Jun 2011
    Drogheda Ireland
    Comfort wise the F1's is the better tyre. It also gives more feedback through the steering and the car responds quicker to direction changes. I found the Conti to give a vague steering feel especially in the wet.
    The roads where wet today so it would be unfair to comment on noise just yet. Although Camskill tyres have the F1 at 70dB and the Conti S Cont 5 at 72dB.. I'll leave further feedback over the coming days when they bed in further.
    VW CC GT 177 DSG
  5. Re: Recommended tyre pressures 245-45/18
    Jan 2013
    114 Post(s)
    Cheers.
  6. Re: Recommended tyre pressures 245-45/18
    Dec 2010
    CD UK
    6 Post(s)
    OK, I'll stick my head above he parapet here and risk getting shot down:
    I've not experienced them, although the reviews aren't too bad and surprisingly not in the "ditchfinder" category despite what you might expect. 4 season Sailun Atrezzo Z4+AS look a steal at £48 from tyreleader. Remember, I also have a Skoda, so I'm not proud...
    Just don't shoot the messenger.
  7. Re: Recommended tyre pressures 245-45/18
    #17
    Jan 2013
    Lincs
    They look interesting!
    They certainly have a tread that would lend itself to cold temperature ops, but does it have a snow flake symbol for Euro skiing?ea
    Last edited by DieTryin'; 11-04-2015 at 11:47 PM. Reason: tread wear looks weak........
    2006 A6 Avant 2.7 TDI quattro S-Line
    2015 Q5 2.0 TDI S-Line Plus
  8. Re: Recommended tyre pressures 245-45/18
    #18
    Dec 2010
    CD UK
    6 Post(s)
    No obvious 3PMS symbol for Alpine use, but should be adequate in the UK if treated with respect, and the open M+S rating at least means they should eject snow and displace water effectively. Just don't go mad in extremes, or more importantly forget to tell anyone else driving your car. Maxxis and other brands do some similar "covert" all-seasons that are generally categorised as summer patterns, but the tightening noise regs are reducing choice by causing pattern extinction with consequent availability issues sometimes leading to weird pricing for certain sizes.
  9. Re: Recommended tyre pressures 245-45/18
    #19
    Feb 2015
    The far side
    I've got the Bridgestone Turanza OEM and they have the same wear issue, 2 mm in the middle and 4+ on the edges, rears a little deeper but wear pattern the same. I do mainly motorway miles. Years ago I had a similar issue and the tyre dealer said it was due to high speeds and centrifugal forces and was a known issue with low profile tyres?? I have to say this is a first since that car in the 80s.
    So mine are worn out. They have lasted 22500 on the front so not at all bad (motorway miles). I hate the tramlining of the Bridgestones which is worse now they are worn. Audi pays but I have to have premium brands. Any recommends? I'd go Michelin PS3 unless someone has better ideas??
    Mine's a C7 Avant S-Line 2.0 TDI 245/45x18
  10. Re: Recommended tyre pressures 245-45/18
    #20
    Jun 2011
    Drogheda Ireland
    Quote Originally Posted by Thriftmeister View Post
    I have to say I'm very happy with the Goodyear F1's I fitted to the front. They're quieter more comfortable and gripper than the conti 5 they replaced, plus the steering is sharper.
    I'm running these at 29psi and monitoring the wear
    VW CC GT 177 DSG
  1. Increase Tyre size from 225 to 245
    By nicktooley in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-06-2013, 10:20 AM
  2. Please Help 245/45/R17 tyre deals please!
    By vwawudi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-05-2012, 05:07 PM
  3. Tyre choice - 245 40 18
    By xtremist in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-02-2012, 12:24 PM
  4. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  5. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
