Thread: Rear brake pads - replacing
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
  1. Rear brake pads - replacing
    Apr 2010
    Ashford, Middlesex
    How difficult is it to replace the rear pads on a B8 Avant? MOT last week had both sides wearing thin as advisories, so they will want changing at some point. Just wondering if I would be as well doing it myself.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  2. Re: Rear brake pads - replacing
    Nov 2013
    Cumbria
    Depends if you have an electronic handbrake ? If you do, you will need a VCDS cable to release the parking brake.
    Apart from that, they are straight forward. Use a piston re-wind tool for the rears.
    Audi A6 C7 Avant - quattro, black edition sline - 3.0 BiTDi
    Audi A3 8PA - quattro, black edition sline - 2.0T
    Audi A4 B8 Avant SLine - 3.2 V6 Quattro - now sold
    Audi A3 8P - 2.0T Quattro - sold
    Audi A4 B7 Avant - 2.0T - heap of junk, now gone!
  3. Re: Rear brake pads - replacing
    Apr 2010
    Ashford, Middlesex
    I have the electronic handbrake, and access to VCDS so that bit should be OK - I don't have a re-wind tool though, so the cost of that might outweigh the saving of doing them myself. Is the tool a specific Audi/VAG fellow, or is it generally available?
  4. Re: Rear brake pads - replacing
    Nov 2013
    Cumbria
    Rewind tool is about £15 and is a standard bit of kit. Well worth the money - saves using a clamp on the fronts as well!
    It is a tad tight working on the rears but manageable! I've got quattro so even more so, especially when replacing the discs.
    I know when working on my brakes that they are done correctly.....clean, lube etc. Most garages just remove pads and whack a new set in!
  5. Re: Rear brake pads - replacing
    Aug 2011
    Meath
    You don't need the rewind tool FC as you have VCDS. When doing the fronts crack the bleed nipple 1/3 of a turn or so before you push the piston in, it will weep a little fluid but save your ABS pump, apart from that just clean the callipers well with a wire brush and put a little red grease on the guide pins. You'll save at least the cost of a night away for you and Mrs Controller
  6. Re: Rear brake pads - replacing
    Apr 2010
    Ashford, Middlesex
    Fronts are fine, it is only the rears apparently - maybe the fronts were replaced not long before I bought the car? It's a rare thing for me to change brakes as I tend to be very light footed
  7. Re: Rear brake pads - replacing
    Aug 2011
    Meath
    Rears are easy you'll still save the price of a good bottle of malt and a fish supper
  8. Re: Rear brake pads - replacing
    Ardfern
    8 Post(s)
    As said, it is an easy job. I don't think a rewind tool is required though. so far as I recall, when I did the job, I was able to simply press the pistons back.
    If you are replacing the pads, consider whether it is worth changing the discs at the same time.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  9. Re: Rear brake pads - replacing
    Nov 2013
    Cumbria
    Thats interesting - when I've done my rear pads the piston doesn't retract all the way with VCDS. I find it needs an extra push back before I can get the caliper back on! Sticky pistons or dodgy motor ?
  10. Re: Rear brake pads - replacing
    Apr 2010
    Ashford, Middlesex
    Thanks guys
    I will get some pads ordered next pay day - any brands good or bad?
  1. Replacing rear brake pads
    By Will3001 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-11-2014, 06:54 PM
  2. Right.. Rear Brake Pads need replacing...
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2011, 09:06 AM
  3. replacing front and rear brake discs and pads
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2009, 10:41 PM
  4. Replacing rear brake disks and pads
    By tatham in forum Early Passat Forum - Pre 97
    Last Post: 19-07-2008, 10:11 PM
  5. Replacing rear brake pads on passat B6
    By PNS2007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-07-2008, 10:10 PM
