Thread: Factory fitted towbar wiring
  1. Factory fitted towbar wiring
    Apr 2012
    Northumberland
    As all VAG cars appear to come from the factory with a 13 pin plug, but only 10 sockets, there must be someone out there who is supplying the parts to convert the factory set up to something that is compatible with the requirements of the caravan towing community.
    If so please make yourselves known!....
    I know it only needs a smart relay and some connections, but it will be a lot easier if the correct parts are available to keep it looking like it should and not an afterthought.
    Car make and model are irrelevant, all VAG group cars whether Audi, VW or Skoda would appear to have the same issues. As it happens in this case it is a 2010 Q5 with factory fitted tow bar.
  2. Re: Factory fitted towbar wiring
    Apr 2012
    Northumberland
    So after doing some digging around, i think i need the Westfalia extension kit 300 025 300 113.
    anyone care to comment please?
  3. Re: Factory fitted towbar wiring
    Feb 2009
    West Yorkshire
    10 Post(s)
    I just got a 13 to 7 pin adapter. Didn't know there was a 10 pin. Learning all the time.
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  4. Re: Factory fitted towbar wiring
    Mar 2009
    Manchester, England
    Hi, If it was fitted at the factory when the vehicle was built then there isn't a kit you can buy, if it was fitted with genuine Audi parts by the dealers as an extra then there are different extension kits the 300025, 300027 and the 300028 all ending in 300113 (Which we sell)
    If it does turn out ot be factory built then the cheapest way would be to use a split charge relay and wire it yourself.
    Thanks Adam.
    PF Jones Towbars | National Mobile Towbar Fitting | Audi Towbars
    We will beat any like for like price on all Witter and Westfalia Towbars 0161 872 4755
  5. Re: Factory fitted towbar wiring
    Apr 2012
    Northumberland
    Factory fitted, only ten of the thirteen pins populated.
    what on earth they are thinking of beats me!.....
  6. Re: Factory fitted towbar wiring
    Mar 2009
    Manchester, England
    I Agree, very stupid to assume that nobody intends to tow a caravan but that's the way they do it at the factory, we can sometimes get the pins to populate the socket then your cheapest option would be to use a split charge relay (no splicing into the cars loom is required as you just need to run seperate live wires to the battery) http://www.pfjones.co.uk/towbar-elec...lay-tec3m.html
    Give us a call Monday to see if we have some pins.
    Thanks Adam 0161 886 5796
  7. Re: Factory fitted towbar wiring
    Jul 2016
    Launceston Cornwall
    Ecellent that link was helpful
  1. Please Help Factory fitted Sub wiring block
    By jamie.hayles.5 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-02-2015, 01:05 PM
  2. Do you have factory fitted: ACC & Towbar and VCDS?
    By Zenerdiode in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-06-2014, 02:38 PM
  3. factory towbar
    By creedxup in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-11-2008, 03:08 PM
  4. Factory fit 13pin towbar wiring incomplete
    By slepingcaveman in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 28-06-2008, 09:05 PM
  5. Factory fit 13pin towbar wiring incomplete
    By slepingcaveman in forum The Commercial Range
    Last Post: 28-06-2008, 08:58 PM
