Thread: Is it possible to repair a broken glove box door hinge?
  1. Is it possible to repair a broken glove box door hinge?
    Jan 2009
    Hinge has snapped on glovebox door. I've removed the whole glovebox but the 'pin' on which the hinge pivots doesn't want to come out and I can't see any easy way of doing it. Has anyone managed to repair one of these, or do you just replace the whole shebang?
  2. Re: Is it possible to repair a broken glove box door hinge?
    Southern County Softy
    20 Post(s)
    Think there's a how to on here, if not try Google. .
    A4 2.5 tdi QS (mapped)
  3. Re: Is it possible to repair a broken glove box door hinge?
    20 Post(s)
    2004 Audi A4 3.0 B6 glovebox repair Part 1 of 4: 2004 Audi A4 3.0 B6 glovebox repair Part 1 of 4 - YouTube
  4. Re: Is it possible to repair a broken glove box door hinge?
    Jul 2007
    somerset
    8 Post(s)
    Hi I repaired mine by shaping a piece of 1mm thick steel metal plate and drilling holes and using self tappers try to follow the curved contours of the hinge, use some araldite and screw the lot together, I did mine by removing the glovebox only, the pins will come out but they are really tight, I recall having to drill some holes on a very acute angle, so either use a short drill or an extra long one. They only break because the dampers get too tight, which stresses the hinge, some people remove the damper altogether, but I sprayed mine with wd40 to make it much smoother.
  5. Re: Is it possible to repair a broken glove box door hinge?
    Jan 2009
    Thanks guys
    I've managed to get the pins out using pincers to grip around the back of the pin head, then hammer out. Wasn't too bad in the end.
    I did find this also
    Question A4 B6 Glove box hinge
  6. Re: Is it possible to repair a broken glove box door hinge?
    Jan 2009
    Birmingham
    36 Post(s)
  1. Please Help A4 glove box hinge replacement
    By Buckster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-03-2013, 04:47 PM
  2. Dashboard glove box hinge
    By Capt T in forum Alhambra
    Last Post: 21-02-2013, 09:13 PM
  3. Question A4 B6 Glove box hinge
    By bumble in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-05-2012, 10:54 PM
  4. Help! Glove box door Latch broken off Passat b5 est 2003
    By FARA in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-01-2011, 08:19 PM
  5. Broken Hinge on Glove box
    By ian vincent in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-01-2009, 04:58 PM
