Thread: Audi A6 Avant rear indicator bulb replacement, how?
  1. Audi A6 Avant rear indicator bulb replacement, how?
    Mar 2014
    Romford, Havering
    I have read some content online to try and find out how to replace my rear nearside indicator on my 2007 A6 Le Mans Avant.
    I have found the black over sized screw and used a flat hear to release it, however it appears the light cluster is still being held on pretty tight, only loose where the screw was undone.
    Can anyone walk me through this process please?
    I appreciate that more screw removal is required but I need some guidance as I don't want to remove anything unnecessary.
    Hope some one can help.. happy to post photos of what I can see.
  2. Re: Audi A6 Avant rear indicator bulb replacement, how?
    Aug 2013
    Embra
  3. Re: Audi A6 Avant rear indicator bulb replacement, how?
    Mar 2014
    Romford, Havering
    I have read this article , however it doesn't allow me to access the photos so am not sure what elements I am trying to prise out and feel I might break something if I guess.
    Again, if anyone can shed some light beyond the black screw element at the top of the fitting in order to release the light fitting, would be appreciated.
  4. Re: Audi A6 Avant rear indicator bulb replacement, how?
    Sep 2011
    Lurking over a keyboard ...
    You can't view images as I accidentally deleted my images on VWAF, I will reupload the images this evening as they are not on the PC I currently have access to .
    ATB
    G
  5. Re: Audi A6 Avant rear indicator bulb replacement, how?
    Mar 2014
    Romford, Havering
    Thanks appreciate it.
  6. Re: Audi A6 Avant rear indicator bulb replacement, how?
    Sep 2011
    Images restored .
  1. Le Mans Avant Led Rear Light Bulb Replacement £58. !!
    By Furion in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-05-2013, 09:03 AM
  2. A6 Avant 2006 model - change left side rear indicator bulb
    By Chris Leafe in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-02-2013, 08:05 PM
  3. Indicator bulb replacement
    By DafC in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2010, 10:28 AM
  4. Please Help Replacement of rear light bulb. Audi A4 Avant
    By RoyD in forum New Member Introductions
    Last Post: 04-04-2009, 03:16 PM
  5. Changing rear indicator bulb on A4 Avant '02?
    By tails in forum Audi A4 - Archive Topics
    Last Post: 30-05-2007, 11:06 PM
