Thread: Trying to program additional/replacement FOB Remote on my Audi
Results 1 to 10 of 18
  1. Trying to program additional/replacement FOB Remote on my Audi
    Feb 2015
    Panama, Panama
    I bought my Audi A4 2008 used and the seller just gave me one key/FOB.
    I obtained a second used FOB somewhere else, and had a blank key cut, so at least the physical part works: The key into the door unlocks the car, and the key into the ignition also starts the car (and immediately afterwards shuts down as expected, because of the unrecognized immobilizer chip).
    As the second part of this process, and before I take it for the [expensive] dealer to attempt to program the immobilizer of the new key into the car's computer, I am trying to link the FOB Remote to my car (an Audi A4 2008) so that it locks and unlocks the doors using the procedure described here DIY: How to program your Audi flip key fob. but I have not not been able to make this part work, when pressing the unlock button on the remote does not seem to be recognized by the car.
    So I went to confirm the info printed on both keys, the "new" one and the one that Works, they are almost identical:
    "New":
    06 575 600 22S
    8e0 837 220 Q
    433MHz
    Mine:
    06 575 600 23S
    8e0 837 220 Q
    433MHz
    My two questions are:
    1. Based on the above, do you think the new FOB would simply not work with my car, because its different? or may I be doing something wrong?
    2. And even if the remote does not work because its just not the right one, do you think it would still be worth taking it to the dealer to attempt to program it into the immobilizer of the car? ($$$)
    Thanks!
  2. Re: Trying to program additional/replacement FOB Remote on my Audi
    Aug 2011
    Meath
    There's a transponder inside the key. You need the secret key code (SKC) from an Audi Main dealer. You also need a new transponder key and the services of a locksmith or someone with VCDS. Cheapest option go direct to a dealer!
  3. Re: Trying to program additional/replacement FOB Remote on my Audi
    Feb 2015
    Panama, Panama
    Thanks!
    Yes, I am aware I cannot avoid going to the dealer to get the code and program the immobilizer chip, that's why I am trying the remote door lock/unlock first.
    My question is, based on the scenario I am describing, do you think it would even work... i mean, is it worth even attempting to take they key to the dealer?
  4. Re: Trying to program additional/replacement FOB Remote on my Audi
    Aug 2011
    Meath
    It depends on the year of the car some keys can't have the transponder replaced in that case you need a dealer, he has to connect the car to Audi as he doesn't have the SKC
  5. Re: Trying to program additional/replacement FOB Remote on my Audi
    7 Post(s)
    I'm no expert but as I understand it....
    Immo 3 or newer (2002 on approx) transponders are write once so yours will not be able to be coded.
    You can obtain just the glass transponder and fit it to the old key
    You can obtain a cable and software that will retrieve the SKC and allow you to code the key.
    I'm about to embark upon this little adventure myself, I've got a new key with virgin / uncoded transponder in it and have obtained the cable and software for grabbing the SKC, both for less than £50, which beats the locksmith price of £150+ and really beats the dealer price of £200+
    I'm getting the blade cut at the weekend and will then have a go at coding it. I intend to use the cable and software I've not named but is widely available an very easily identified with a few google searches to get the SKC but then use VCDS to do the actual coding.
    It could all go horribly wrong but I'm sure it will be a great laugh having a go!
  6. Re: Trying to program additional/replacement FOB Remote on my Audi
    Aug 2011
    Meath
    With VCDS and the key code it's a doddle
  7. Re: Trying to program additional/replacement FOB Remote on my Audi
    Jun 2008
    Quote Originally Posted by BigCol View Post
    Can you point me in the right direction for what you purchase as I need the same, I've already go the virgin Id48 immo chip and just need to go further
  8. Re: Trying to program additional/replacement FOB Remote on my Audi
    Feb 2015
    Panama, Panama
    Thanks, interesting info. I am also not an expert and it is clear you've done more research tan myself.
    By glass transponder, do you mean the immobilizer chip? I was under the impression that it is the car that is programmed for the chip and not the other way around.
    Also I thought that the immobilizer chip on the FOB is different and separate from the lock/unlock function via Remote... at this stage I am just trying to get the lock unlock working, and I am wondering if the procedure I am trying or if the remote I got are not the right ones for the car.
    Yes, but again at this stage I think i'd rather do the immobilizer part at the dealer... but I really need to be sure I did my homework properly, specially the dealership are very... "sensitive" to people who come into their shop claiming they have a clue. For example, the guy that cut my key did not appreciate me not buying one of his, so he did not even want to sell me a key battery afterwards!
    Yeah, agreed! And good luck on the adventure! Hoping to read from your success son.
  9. Re: Trying to program additional/replacement FOB Remote on my Audi
    7 Post(s)
    Just a bit of feedback. My adventure was successful and I now have two fully working keys.
    Total cost was about £60 which is considerably cheaper than the £150 a locksmith would have wanted and £200 the dealer would have wanted.
    2 0 0
  10. Re: Trying to program additional/replacement FOB Remote on my Audi
    Jun 2008
    I'm in need of the same thing - can you advise what software and cable you purchased please
  1. Key Fob program settings
    By Malarith in forum Golf MK6 - 2009 - 2013
    Last Post: 01-04-2010, 04:27 PM
  2. A4 remote key fob replacement
    By tuscan440 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-12-2009, 06:11 PM
  3. How to program a new key fob
    By Fatboyjarv in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-05-2009, 08:07 PM
  4. how to program a 3 button fob for 01 passat
    By explorer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 04:43 AM
  5. finding a new replacement remote key fob
    By TheSource in forum Golf MK4 - 1999 - 2004
    Last Post: 02-11-2007, 01:38 PM
