Thread: HELP. GOLF GTI airbag light on
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. HELP. GOLF GTI airbag light on
    Feb 2015
    United Kingdom
    HELP HELP HELP, Can anyone help me with my airbag light issue. i have just bought a 2000 reg mk4 2.0 gti and it has the dreaded airbag light on dash. i have finished all other work that it needed doing to it to get it ready for its mot, but i do not own a vag diagnostic tool and they are pretty expensive. i am a bit strapped for cash at the moment but i am willing to do a favour mechanicaly in return for help given. need to find out what is wrong with the airbag system to fix it. is there anyone anyone in the stoke on trent area who is willing to help. thanks in advance.
  2. Re: HELP. GOLF GTI airbag light on
    Aug 2011
    Meath
    https://www.google.com/maps/d/viewer...8.kMTwqF0PoXwc
    You can buy a cheapo handheld scanner for 30 notes
  3. Re: HELP. GOLF GTI airbag light on
    Pembrokeshire
    22 Post(s)
    no airbag warning light at all, can't fail mot .
  4. Re: HELP. GOLF GTI airbag light on
    Aug 2011
    Meath
    Do they not have to go on and then off? Plenty of cars in Ireland have the air-bag light on the same circuit as the ABS light
  5. Re: HELP. GOLF GTI airbag light on
    Pembrokeshire
    22 Post(s)
    lol, thats a way around it. no, here, by the letter of the mot rules, if the airbag light stays on, it fails. if there is no light at all, not even one when you turn the ignition on, then it is presumed its not fitted with airbags so has to pass. its easy to see an abs pump, sensors etc, but hard to see airba components. the fact the steering wheel says 'SRS' dosn't count as you may have fitted an airbag steering wheel because it looks nice.
    1 1 0
  6. Re: HELP. GOLF GTI airbag light on
    Feb 2015
    United Kingdom
    hi , thanks for the advice but i have 2 cheapo diag tools and both dont work on my car. also here in england if the light does not come on then it is a mot fail. i have taken a car with bulb out and failed .
  7. Re: HELP. GOLF GTI airbag light on
    Aug 2011
    Meath
  8. Re: HELP. GOLF GTI airbag light on
    Jan 2015
    Driffield, East Yorkshire
    If the air bag/SRS warning light does not come on and go out to show the system is armed and working it WILL fail the MOT. It's the same with the ABS light, that MUST come on and go out.
    Air bag faults are usually due to the pad sensors in the seats, they tend to wear and the mesh gets broken. Modern airbag systems tend to only arm for the passenger side when it detects a passenger in the seat. Drivers air bags are always armed for obvious reasons.
    The simple fix to this is to get a bypass unit so the airbag is always armed regardless of a passenger in the seat. It's a small unit that plugs in under the seat instead of the sensor mat. Sadly it will NOT put out the airbag light, that needs a system reset to clear the fault. A scanner will not solve the problem, all it'll do is show the fault code. I'm not sure but you may be able to get the Golf software off Ebay and relevant connecting cable to plug in your laptop into the car; I know you can for BMW, Mini and Rolls Royce/Bentley.
  9. Re: HELP. GOLF GTI airbag light on
    Aug 2011
    Meath
    The little scan tool I posted a link to will reset the air-bag light when the problem is rectified
  10. Re: HELP. GOLF GTI airbag light on
    Jan 2015
    Quote Originally Posted by Doctle Odd View Post
    Scan tools usually don't. The clue is in the name
    If that one does then it's all good
  1. Airbag light on - Golf MK5
    By jellybeangreen2 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-01-2015, 10:42 PM
  2. golf mk4 tdi airbag light and abs light
    By swally34 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-06-2013, 09:12 PM
  3. Please Help mk4 golf airbag light
    By golf01 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-10-2010, 01:10 PM
  4. Replies: 0
    Last Post: 03-06-2009, 05:15 PM
  5. Replies: 2
    Last Post: 01-04-2009, 07:55 PM
