Thread: rear shock absorber replacement
Results 1 to 10 of 13
  1. rear shock absorber replacement
    Feb 2015
    Stourbridge
    Hi, I am looking to replace the rear shocks on a 2010 CC for a friend. I am pretty handy with the tools but need to know if they need to be setup once installed using vagcom due to the electronic ride adjustment on the vehicle. Also if anyone has any tips or trade secrets on the job I would appreciate it
  2. Re: rear shock absorber replacement
    Feb 2015
    Stourbridge
    Bump
  3. Re: rear shock absorber replacement
    130 Post(s)
    1972 Post(s)
    It is a pain Monroe stopped offering these as they are only available genuine now. Anyway, fit and forget, just check for system fault codes.
  4. Re: rear shock absorber replacement
    Jun 2015
    Ballymena
    I've just bought a 2011 Passat CC and I may have rear shocks to replace before MOT as the last one flagged an advisory on a rear shock.
    Are these only available from VW now?
  5. Re: rear shock absorber replacement
    130 Post(s)
    1972 Post(s)
    It depends on which dampers it has. Base model non electronic then Sachs, Boge, Bilstein, TRW, Monroe etc and VW even do their own "ECO" versions for about £67 a side. If they are the electronic type, only Monroe have ever listed them and they are flagged as no longer available so prepare to bend over and chomp down on that pillow, 213 times, each side....
  6. Re: rear shock absorber replacement
    Jun 2015
    Ballymena
    seen these on ebay but hunted around on monroe site and its mentions something about not suiatble for 18 inch wheels
    2x MONROE CES REAR SHOCK ABSORBERS VW PASSAT CC 2008-2012 C1514 | eBay
  7. Re: rear shock absorber replacement
    130 Post(s)
    1972 Post(s)
    They are suitable for cars with the PR-1JP suspension as shown on the cars data sticker. I looked on my system and the part number has changed slightly which threw me and they cross reference over to the correct VW number. A much better price.
  8. Re: rear shock absorber replacement
    Jun 2015
    Ballymena
    that's good to know ...
    failing that there's always the http://www.awesomegti.com/kw-ddc-plu...tronic-dampers
  9. Re: rear shock absorber replacement
    130 Post(s)
    1972 Post(s)
    I did a set of those on a Scirocco (much the same setup) and it absolutely buggered the ride quality. Fine in Der Fatherland with their nice roads but awful here.
  10. Re: rear shock absorber replacement
    Jun 2015
    Ballymena
    Shock Absorber MONROE CES Technology, Rear Axle VW Passat CC 2.0 TDI by Monroe C1514 - rexbo.eu site that says not for 18 inch rim - confusing - what difference would an 18 inch rim make
    Vehicle-specific Criteria
    • Fitting Position: Rear Axle
    • Suspension: for vehicles with electronic suspension control
    • not for rim size: 18 Inch
    • not for equipment variant: R 36
    Criteria
    • Shock Absorber Mounting Type: Top pin
    • Shock Absorber Mounting Type: Bottom eye
    • Shock Absorber System: Electronically adjustable shock strength
    • Shock Absorber Type: Gas Pressure
    • Operating Mode: Electronic
    Tags
    Damper Suspension
    » See all vehicles for this part.
    Replace No
    • C1517
    EAN Code
    • 5412096438875
  1. Signs of oil on rear shock absorber
    By gianton in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2013, 06:18 PM
  2. rear shock absorber failure
    By gtv160 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-03-2011, 06:15 PM
  3. Touran rear shock absorber diagram
    By jrross in forum Touran - Sharan - Caravelle
    Last Post: 23-09-2010, 10:05 PM
  4. Shock Absorber replacement
    By sprintevo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-12-2009, 06:21 PM
  5. B6 Estate rear shock absorber lower mounts
    By Motorway in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-04-2008, 09:07 PM
