Thread: sticking clutch pedal
  1. sticking clutch pedal
    Jun 2010
    London
    Hi gents. Anyone else had a problem with clutch sticking pedal 6speed box? pedal sticking half way, but i have no problems with selecting gears. any help appreciated.
  2. Re: sticking clutch pedal
    Mar 2013
    Virginia Co Cavan Ireland
    It's most likely the clutch master cylinder or more to the point the rod that goes from the pedal to the cylinder buddy.
    Mick
    Mick
    99 Bora Tdi
  3. Re: sticking clutch pedal
    Jun 2010
    London
    how do i know which cylinder? master or slave? any way to check it?
  4. Re: sticking clutch pedal
    Mar 2013
    Master, the rod is plastic and breaks where it goes from the pedal to the cylinder, needs a new unit, not too difficult to fit just a bit fiddly
    Mick
    Mick
    99 Bora Tdi
  5. Re: sticking clutch pedal
    Jun 2010
    London
    new master cylinder fitted but the problem still there... now could be slave cylinder, or clutch release bearing or problem with a gearbox???
  6. Re: sticking clutch pedal
    Feb 2015
    London
    Sorry to say this but I have been reading around about this but after people have replaced cylinders and throw out bearings it ends up basically requiring a new engine due to too much crankshaft end play.
    I have a 2004 Altea 1.9TDI with 130K on the clock and the half way down clutch issue has been going on for several weeks getting worse and worse. Often I have to turn off the engine to get it in and out of gear as the clutch seems to be slightly permanently engaged.
    Back in the day I had a MK1 Golf and it just had a manual adjuster surrounding the clutch cable to adjust it!
    Honestly I have not had a quote yet too scared
  1. Please Help Golf MK 5 sticking clutch pedal
    By Cheshire_cab in forum Golf MK5 - 2004 - 2009
    Last Post: 30-09-2010, 11:18 AM
  2. Golf Sticking Clutch Pedal.
    By dryerman in forum Golf MK4 - 1999 - 2004
    Last Post: 23-01-2010, 02:51 PM
  3. Please Help a3 sticking clutch pedal
    By karl150 in forum Audi A3 - Archive Topics
    Last Post: 23-02-2009, 11:01 PM
  4. Sticking clutch pedal
    By zuffler in forum Audi A3 - Archive Topics
    Last Post: 18-02-2008, 10:45 PM
  5. Sticking Clutch Pedal
    By Sesame in forum Passat - Archive Topics
    Last Post: 31-05-2006, 11:39 PM
