Thread: Coolant drain plug location 1.9tdi AVB
  1. Coolant drain plug location 1.9tdi AVB
    Jan 2015
    London, UK
    I just bought an audi a4 1.9tdi AVB and would like to flush out the coolant as it looks clear and I don't know the history of it. However I cannot for the life of me find where to drain the coolant from. Could somebody please point me in the right direction. Pictures would be best.
  2. Re: Coolant drain plug location 1.9tdi AVB
    Aug 2011
    Meath
    it's on the bottom left of the radiator as viewed from the drivers seat. Take a pipe off the oil cooler and drain the block completely
    1 1 0
  3. Re: Coolant drain plug location 1.9tdi AVB
    Jan 2015
    London, UK
    Is this the right place? Because I did try and unscrew that little tap, it turned about half a turn but nothing happened.
  4. Re: Coolant drain plug location 1.9tdi AVB
    Aug 2011
    Meath
    Quote Originally Posted by Sp00ks View Post
    Turn and pull towards rear of car
  5. Re: Coolant drain plug location 1.9tdi AVB
    Jan 2015
    London, UK
    Thanks for your help unfortunately I had no luck, access is really tight as I have no ramps, I was using a curb for access. Like I said the tap turns half a turn but nothing happens, I tried pulling it out using pliers after making the half turn but no luck. Will try and book it into a garage for a coolant flush asap. Just trying to create a baseline for service/maintenance. Did the oil, oil filter, air filter, pollen filter and fuel filter so far. Also changed the thermostat as the car wasn't reaching temperature, it is now and sits at 90.
    Ok I have just done some more research, and I have found this:
    Open this drain ****, it will twist to the left 90 degrees then pull out a little, then twist again 90 degrees then pull out more. *Note, it does NOT pull out all the way! This will open the valve and the coolant will begin to drain on the side of the valve.
  6. Re: Coolant drain plug location 1.9tdi AVB
    Aug 2011
    Meath
    its easier from the top, you did all the other jibs this one is easier than you think
  1. Question AC drain location (2009)
    By rline1983 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-06-2014, 01:41 PM
  2. Coolant leak from 1.9TDi 99' avant (AFN) - core plug
    By Granto in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-01-2014, 12:21 PM
  3. condensate drain location
    By toptek in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-08-2011, 08:02 PM
  4. Please Help 2003 Audi A4 1.9tdi AVB Manual Gearbox
    By MG1424 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2010, 04:59 PM
  5. battery drain plug
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2007, 10:00 AM
