Thread: Engine Speed sensor G28 removal?
  1. Engine Speed sensor G28 removal?
    Mar 2007
    Brum
    Hi guys,
    Had my first ever proper breakdown the other day. My Passat just simply cut out whilst stationary at some lights with the engine management garage message on the dash. It wouldn't restart so had to get the RAC out to help. They towed me to a safer spot then ran their diag's and told me it was an intermittent fault on the engine speed sensor. The RAC tech said try to start it again and it fired up straight away as normal. It had been roughly an hour after it cut out and I had been trying it every now and then but with no luck. 10 minutes later the fault came back but this time while I was driving - the dash binged, the rev gauge dropped to nothing, it kind of stuttered once and then came back to life in limp mode. Got it home to scan myself and got the following:-
    1 Fault Found:
    16706 - Engine Speed Sensor (G28)
    P0322 - 006 - No Signal - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 276122 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:40:32
    Freeze Frame:
    RPM: 0 /min
    Text: 80 Nm
    Speed: 46.0 km/h
    Bin. Bits: 00000001
    Bin. Bits: 01000011
    (no units): 11.0
    Angle: 0.0 °
    This seems to tie up with the RAC so got it round to a local garage who said he'd done speed sensors on other VW's but not a Passat before. Anyway got a call later yesterday afternoon saying he can't do it as he can't physically turn the bolt which secures the old sensor to the block. Is this normal or usual?
    My cars a 2006 Passat Sport with the 2.0 Tdi BKP engine having covered just over 171k miles. Clutch and flywheel were replaced about 60k ago if that has any bearing on the matter at all.
    From this mornings experience it seems to start OK when it's cold and runs fine until after about 4 miles or about 15 - 20 mins it comes back into limp and once stopped won't restart until it's cold again.
    Any guidance on getting the sensor out will be much appreciated. I'm hoping it is just the sensor?
    Cheers,
    Scottiedogg
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  2. Re: Engine Speed sensor G28 removal?
    Sep 2008
    SE London
    If you're current indie can't remove the bolt, then you'll have to find someone that can. I think, in Brum there's more than one VAG indie?
    I'm not a Derv head. But seem to recall someone posting about having changed G28 and still getting a fault. Turned out they changed for a cheeepo Chinese fake from a parts' shop. So think worthwhile getting the real OEM part from dealer spares. Also get the ETKA diagram printout of its location. You'll have to give them your VIN #so they can locate the correct replacement.
    Might be necessary to run a VCDS alignment afterward. So in searching for a VAG indie ask them whether they have VCDS?
    Good luck!
  3. Re: Engine Speed sensor G28 removal?
    Mar 2007
    Brum
    Quote Originally Posted by RichardSEL View Post
    Good luck!
    Managed to get the sensor changed late on Saturday. All seems to be OK now. Is it likely that the sensor could now be out of alignment? If so how do I check this and where in VCDS is the alignment?
    Cheers,
    Scott
  4. Re: Engine Speed sensor G28 removal?
    Dec 2014
    United Kingdom
    Hi I have a reverse light problem .i have changed the bulbs but didn't resolve the problem .no lights in dash ..SMTP what's the problem ..can any one help me thanks
    Golf 1.9tdi. 54 reg
  5. Re: Engine Speed sensor G28 removal?
    Sep 2008
    SE London
    Thisa thread is about G28 speed sensor in the Passat B6 2005-2010 forum -- if you make a new post (use the New Thread button) in the forum for your car I'm sure someone in there will be able to help. Telll them what's wrong with your reverse lights too?
    Good luck!
    Post in here: Golf MK5 - 2004 - 2009
  1. How To G28 Engine Speed Sensor
    By Silver in forum Polo - Derby - Lupo - Fox
    Last Post: 25-09-2016, 03:34 PM
  2. Engine speed sensor G28
    By simj34 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2013, 09:19 AM
  3. Replies: 4
    Last Post: 21-05-2012, 10:47 PM
  4. Please Help Engine Speed Sensor G28, "Emission Garage" Car not Starting
    By moinkk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-05-2012, 12:11 PM
  5. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
