Thread: Permanent Deactivation of start stop function - Audi A7
Results 1 to 10 of 10
  1. Permanent Deactivation of start stop function - Audi A7
    Nov 2014
    Hertfordshire UK
    Hi all, Using advice from a previous thread about a7 vcds trick I've tried to permanently disable the start/stop function on my 2011 A7 as follows....
    Module 10 park/steer assist
    adaptation
    drop down box "deactivation of start-stop function"
    set the stored value to "start stop function in control module active" in the next box
    Do it
    Having done this to letter its made no difference what so ever!? am i doing some thing wrong, help from anyone please.
    0 0 1
  2. Re: Permanent Deactivation of start stop function - Audi A7
    Feb 2013
    Gloucester
    57 Post(s)
    I found it somewhere in VCDS but didn't try it as I like the feature. Will have a look later and see if I can find it
  3. Re: Permanent Deactivation of start stop function - Audi A7
    Aug 2012
    Glasgow
    I have an a8 and I just disable mine from the dash switch.
    It's a crazy idea, nearly as bad as those front driving lamps on a lot of cars that come on depending on the direction of steering.. They were on my d3 a8 but thankfully not on my d4..
    Sent from my iPad using Tapatalk HD
  4. Re: Permanent Deactivation of start stop function - Audi A7
    Nov 2014
    Hertfordshire UK
    Hi all, just wanted to give you an update, after much research ive finally successfully swithed the auto start stop on my 2011 Audi A7, below is how i did it using a method from a Q5 owners forum....i couldn't be happier as now when i press the button on the dashboard it stays off and doesn't default back to being on when i get in the car the next time. Personally i think *** is a joke with an s tronic gearbox, its left me in a few really tricky situations on roundabouts and almost caused me to crash once.
    This is how i did it.......
    - Module 09-Cent. Elec.
    - Enter Security Code (shown up by default) (mine was 20113)
    - Adaptation, Type Channel 34 and hit Read button, it should show the factory default number.
    - The value of mine was 20
    - Change this value to 64
    - Test and then save
    Happy days ��
    1 1 0
  5. Re: Permanent Deactivation of start stop function - Audi A7
    Apr 2016
    Slovenia
    I have few questions regarding this mod:
    - did you add 64 to the original value or did you change to 64? Because the instructions are that you have to add 64 to original value, which would activate memory function for start/stop and reverse the light function (active only when start/stop is enabled)
    - does it work ok for you? And does it always remember the last selected position (enabled or disabled) or did it sometimes defaulted back in possition start/stop enabled
    - which 09-CE unit does your car have
  6. Re: Permanent Deactivation of start stop function - Audi A7
    Feb 2016
    Hungary
    116 Post(s)
    Please refer to this topic's first post, Trick #25:
    A6 C7 VCDS Tricks
    Because the above post's settings seems incorrect to me.
    This trick was confirmed a lot on the A7 models, some strange behaviour was reported, but mostly this trick working without any problem. Please refer to this topic: To "save the last selected option", and the "invert the switch option" are two different selections. If you wish the car to remember your last setting after an ignition off/on session, then you need to select the "remember the last setting" option.
    1 1 0
  7. Re: Permanent Deactivation of start stop function - Audi A7
    Apr 2016
    Slovenia
    Thx. Yes the trick 25 should be the correct procedure and save the last selected option would be the best (so adding 32 to original 20). But in A6 this does not work always. It can remember the last state, but it is quite random. For example, once it will remember even if the car will be left for more than a day, next time it will turn on even if the car was left for only a few minutes (and the S/S system was turned off when the car was turned off).
    Do you have any suggestions regarding this?
  8. Re: Permanent Deactivation of start stop function - Audi A7
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by mtl_slo View Post
    I use the memory setting, and it's working fine for me.
    About the solution? Somebody posted your issue into the A6 tips&tricks topic just some days ago, and I replied to this, that I felt this feeling when I selected the "inverse the start/stop button" option only. For me the solution was to remove the reverting, and to set the "remember start&stop settings" only. After this change, my problem disappeared and now everything is working fine.
    By this, it's possible that some setups tolerates only one of these options, or even tolerates these options, if you select these for the very same time. So, I can suggest to you to try the other selection OR try both of them for the same time. It may solve your problem, at least in my case, it did. Good luck
    1 1 0
  9. Re: Permanent Deactivation of start stop function - Audi A7
    Apr 2016
    Slovenia
    Thx, I will continue in that post...
  10. Re: Permanent Deactivation of start stop function - Audi A7
    Nov 2014
    Hertfordshire UK
    I changed the value to 64, some say you add 32 to the original value if you want the swith to iluminate the same but the stay off when you start the car the next time, but that didnt work for me so i messed around a bit and with trail and error got it to work with an actual value of 64 stored, its been six months and never once has it switch back on ��
  1. Audi A7 stop/start problem in Eco mode
    By Simon Martin in forum A7 - S7
    Last Post: 22-11-2014, 09:30 AM
  2. Audi stop-start facility
    By fiddler3 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-09-2013, 03:13 PM
  3. Audi A3 start stop issue
    By abz1981 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-12-2012, 11:35 PM
  4. Please Help audi diesel start stop since crash
    By crane in forum 80 - 90
    Last Post: 15-09-2010, 12:45 PM
  5. Audi Starts With Stop-Start Technology
    By Bristle Hound in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-03-2009, 07:03 PM
