Thread: Air intake Temperature sensor location b5.5 pd130 passat
  1. Air intake Temperature sensor location b5.5 pd130 passat
    Dec 2009
    I'm trying to find out where the intake air temperature sensor is on my passat pd130 tdi.
    I ran a health check recently after continuous decreasing fuel economy ( VCDS AND PD TDI ENGINE HEALTH CHECK - PASSAT)
    My temperature reading for the air intake (measuring blocks 7 on vcds) shows ambient temp but then rises with engine temp and fluctuates between 30 & 50 deg c during a drive. according to the health check it should remain constant? Where do I find this sensor as I cannot see one located on the airbox anywhere. I unplugged the sensor on the intake pipe pre intake manifold and that seems to send the reading wild....so is this the sensor? If so it doesn't make sense that temp should be constant as this is air port turbo and intercooler.
    Have also changed fuel temp sensor as it appeared to not be reaching optimum fuel temp reading.
    thanks
    2002 Passat PD 130 TDI Sport Estate
    2003 Golf GT TDI PD 130
  2. Re: Air intake Temperature sensor location b5.5 pd130 passat
    Pembrokeshire
    22 Post(s)
    i belive it to be part of the AMM. MAF to others.
  3. Re: Air intake Temperature sensor location b5.5 pd130 passat
    Dec 2009
    Oh bugger so its integrated meaning the only way to sort that is a new MAF/AMM? Great....so much for a cheaper fix
    I'm guessing this kind of fault will not benefit from spray cleaning the maf either?
    Thanks for the reply
  4. Re: Air intake Temperature sensor location b5.5 pd130 passat
    Pembrokeshire
    22 Post(s)
    i think it is. try disconnecting the amm, the temp reding should go to a default value and stay there.
  5. Re: Air intake Temperature sensor location b5.5 pd130 passat
    Dec 2009
    Ok just tried that. Unplugging maf has no effect on the intake temp.
    Unplugging the the thrust sensor (i think it is), the one on the plastic intake pipe that leads from intercooler to intake sends the temp indication to 135.9 deg.
    So if that's the case I guess there is no intake temp sensor..... or not raw intake air as such.
  1. Replies: 0
    Last Post: 28-12-2012, 05:57 AM
  2. P0112 -Intake Air Temperature sensor
    By routers77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2010, 08:41 PM
  3. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
  4. intake air temperature sensor
    By nathancrowster in forum VCDS - General Questions
    Last Post: 30-07-2008, 07:09 PM
  5. passat Intake Air Tempreature sensor
    By passat1.8T in forum Passat - Archive Topics
    Last Post: 29-12-2006, 01:56 PM
