Thread: Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
  1. Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
    Dec 2014
    manchester, england
    Hi. Would very much appreciate guide lines on how to change the Battery from a standard to a AGM Type as I have retro fitted a Remote Start and Timed Auxiliary Fuel Burner. I understand I have to code via VCDS the new battery specs, but as I planning on purchasing a Varta Silver Dynamic AGM 595 901 085 (95Ah/850CCA) direct from a local supplier it will not have the relavent VAG Part number and serial numbers. Does anybody have these to hand or will VCDS except Varta numbers? Again much appreciated any help as I have dead cold car!!
  2. Re: Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
    Aug 2008
    West Yorkshire
    Changed my battery 3 weeks ago. VCDS will show a drop down box to select the right battery, VARTA been one that it likes. Once selected input the numbers......or just change one of the previous stored numbers
    Go on the VCDS web page, it will show you how to do it, very easy.
    It will then think/know you have a new battery and you should be good to go.
  3. Re: Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
    Aug 2008
    West Yorkshire
  4. Re: Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
    Jun 2006
    UK, Mids
    I replaced mine for a Lion 95Ah AGM just over a year ago, after much googling, I used the code: 000915105CE
    It has been superb.
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
    Component: J0644 BEM H12 0550
    Revision: 00000000 Serial number: 00000000007746
    Shop #: WSC 00976 210 56416
    VCID: 20446925F395753B8D-8075
    Subsystem 1 - Part No: 000 915 105 CE
    Component: von VA0 0000000001
    Coding: 303030393135313035434556413030303030303030303031
    Shop #: WSC 00097 210 19480
    Audi A8 - 2015 - 3.0TDI
  5. Re: Audi A8 D3 2008 4.2 TDi AGM Battery Upgrade
    Dec 2014
    manchester, england
    Thanks everyone, first job tomorrow.
  1. Audi A8 D3 4.2 TDi AGM Battery Upgrade
    By Howdy Doody in forum VCDS - Help Requests
    Last Post: 09-12-2014, 12:23 PM
  2. Question Audi A6 2008 2.0 TDI - Central Locking Problems
    By goldy14 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-11-2014, 07:51 PM
  3. Radio upgrade in 2008 passat
    By Jamied-80 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-09-2013, 06:51 AM
  4. Audi A3 1.9tdi 2008 CHORUS Head-Unit Upgrade
    By sum-vwaudi in forum In Car Entertainment
    Last Post: 11-07-2011, 07:51 PM
  5. Question 2004 Symphony II - 2008 Concert upgrade...
    By randall977 in forum In Car Entertainment
    Last Post: 26-08-2008, 10:40 AM
