Thread: Decarbonising a diesel engine motor
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Decarbonising a diesel engine motor
    Sep 2007
    Tried the water spray method yesterday. Sprayed water in at the EGR valve. Hope that's 'B' in the picture as that's were I sprayed in the water. Engine was at normal running temp. Got plenty of steam vapour out of the exhaust.
    Didn't get the revs up though as on my own Just run at tick over circa 800 rpm. Engine didn't stall.
    Put hoses back together and gave it boot on the drive and a load of soot on the floor.
    Went for a drive and feels as though I have no boost as the motor doesn't respond as it did. What could be wrong?
    Passat Highline 130 TDi
    Polo S (64) 1198cc 2005
  2. Re: Decarbonising a diesel engine motor
    You've sprayed water into the EGR valve to decarbonise your engine?
    I thought this was dismissed as a nonsense method before on here - what was wrong with the car/engine before you did this?
    0 2 0
  3. Re: Decarbonising a diesel engine motor
    Sep 2007
    Quote Originally Posted by Eshrules View Post
    Yes
    Nothing I guess. Just seemed like a good idea at the time. Done 82K and doesn't get run on long distances at the moment or in the near future. Usually 12 mile round trip to work and back
    Didn't know that
  4. Re: Decarbonising a diesel engine motor
    Mar 2008
    Just Cumbria now.
    What's wrong with an Italian tune up?
    Nothing to see here, move along..
    1 2 0
  5. Re: Decarbonising a diesel engine motor
    Pembrokeshire
    22 Post(s)
    when you have taken your boost pipe off, thats the black rubber hose you must have unclipped, you may have dislodged one of the vacuum pipes that controls the turbo. that is unless you have bent a con rod by spraying water in to the engine, it only takes a small amount to do damage . what you have done is actually a really daft idea. i would recommend you don't do it again. if you want to clean the car of carbon, do as hex says.
    3 4 0
  6. Re: Decarbonising a diesel engine motor
    Apr 2013
    Solihull, Great Britain
    A diesel engine works by compressing air into a space over fifteen times smaller than normal. Water doesn't compress, so the moving parts will get damaged trying to compress it. As Zollaf said, it is very likely that you have caused serious damage to your engine by bending the connecting rods.
    If you want to clear the EGR valve and intake manifold of the oily carbon that builds up in high-mileage diesels, take them off the engine, get some carb cleaner and good rubber gloves, and spend a fun morning gently scraping the inside of these components. It's a good idea to get a set of new seals and gaskets as well. Oh, and wear clothing that you don't mind throwing away.
    Although in the case of your engine, I'm afraid that a rebuild or replacement of the entire unit is possibly going to be needed. It's a real shame you didn't put a post on here saying what you were going to do before you did it, so we had a chance to warn you that it was a really bad idea. I hope that it's only a vacuum pipe come loose that's causing the power loss, like Zollaf said.
    12-plate Audi A3 Black Edition 2.0 TFSi S-tronic Sportback in Ice Silver with DVD Sat Nav, Bose sound system, xenon headlights, Bluetooth, voice control, heated full leather seats, full electric driver's seat adjustment, privacy glass, heated auto dimming power-folding mirrors, titanium grey Rotor-style alloys, auto lights & wipers, and tyre pressure monitoring.
    2 3 0
  7. Re: Decarbonising a diesel engine motor
    Pembrokeshire
    22 Post(s)
    i had to do this yesterday to a customers arl powered golf. removed quite a lot of sludge from the egr and manifold, then fitted blanking plates to the egr to stop it happening again.
  8. Re: Decarbonising a diesel engine motor
    Apr 2013
    It's a horrible job, Zoll, I take my hat off to you getting stuck in. The results really speak for themselves, don't they? It made my 60k miler 2.2 TDCi Mondeo as good as new: far smoother, and the dyno showed I had increased the power from 142 BHP to its original 155. Then I added Bluetooth, a decat and bigger intercooler...
    1 1 0
  9. Re: Decarbonising a diesel engine motor
    Pembrokeshire
    22 Post(s)
    oh so well worth it. but after doing one ( i have done many), you soon realise that whatever chemicals you throw at it, only elbow grease really works, physically scraping it off. this leads to me to be able to say that all of these magic cleans, terra clean et al, are snake oil maybe they do make a small difference, but not as much as a proper clean by hand.
    lets hope the op doesn't need an engine rebuild after trying the old water trick.
    incidentally, its te same as driving through a flood, and cars always run worse when they have been driven through a river.
    2 2 0
  10. Re: Decarbonising a diesel engine motor
    Apr 2013
    Yes, the first thing it reminded me of was the old advice, "Keep your vehicle speed low and your engine speed high through a flood" because of getting water in the air intake and avoiding stalling.
    I've heard some good stories about Terra Clean, but probably because the carbon in the combustion chambers is a far cry from the sticky goo in the EGR and manifold!
    It's this EGR business combined with the DPF trouble that made me go for a petrol motor now that my daily commute is just over 5 miles. I've tried cycling but some drivers are lethal! Then there was the day I had used the bike and my boss asked me if I would stand in for him collecting a bloke in a wheelchair (plus suitcase) from the airport...
    Last edited by Kar Krazy; 20-11-2014 at 09:00 AM. Reason: changed "drives" to "drivers"
  1. golf mk4 petrol engine to diesel engine conversion help
    By robokid13 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2014, 07:47 AM
  2. audi 3.0 diesel intake manifold runner motor problem
    By daniel_3855 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-10-2013, 01:07 AM
  3. Misbehaving engine after puting petrol in diesel engine
    By ianbryant in forum Golf MK6 - 2009 - 2013
    Last Post: 02-03-2013, 06:03 AM
  4. Please Help noisy new starter motor polo 6n1 1.9 diesel
    By madbypolo in forum Polo - Derby - Lupo - Fox
    Last Post: 15-01-2011, 09:15 PM
  5. 1.4 16v BCA engine needs new short motor
    By jazzman2007 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2009, 04:16 PM
