Thread: Allroad suspension not lifting
Results 1 to 10 of 11
  1. Allroad suspension not lifting
    Jan 2013
    Skipton UK
    I'm hoping suspension guru BagpipingAndy sees this !
    Yesterday the suspension stopped lifting. There are no warning lights on it has just "stuck" at level 1. When I press the lift button instead of getting the green flashing light there is nothing and no signs of it lifting, it goes green whilst being pressed in but as soon as I let go it goes out.
    Car has not sunk on to bump stops and is sitting level. Is this classic compressor failure ?
    any advice greatly appreciated !
  2. Re: Allroad suspension not lifting
    Ayrshire, Scotland
    18 Post(s)
    Hmmm, not compressor failure,
    so its at level 1 and "looking" ok, if you press the up button does the level 2 green light blink? if it does check the fuse and relay to the compressor,
    if it doesn't blink something is wrong, is it in jack mode? best step is to get the fault codes read it may be the N111 wiring, it gave me symptoms of this but that did put the error light on too?
    get the fault codes and go from there, if you need to wait for fault codes, check fuses in position 5, 7 & 17 in the end of the dash
    regards
    andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Allroad suspension not lifting
    Jan 2013
    Skipton UK
    Quote Originally Posted by bagpipingandy View Post
    regards
    andy
    Thanks Andy for the quick reply !
    correct - sat at level 1 with level 1 green light on and looking ok. Press the up button and nothing. No flashing level 2 light and up button light not on either
    Not in jacking mode. Will it have thrown error codes if no dash warning lights on ?
    Will check fuses
  4. Re: Allroad suspension not lifting
    Ayrshire, Scotland
    18 Post(s)
    yes you can have codes stored with no error light on although not ussually ones to stop the system,
    is teh car running- battery good?
    does it notice you pressin the up button (i think it lights the green light when you press up)
    can you put it in and out of jack mode?
    if the above is all true, and we still dont have fault codes read, for a 1st guess, my punt is the temp sensor on the compressor,
    unplug it to see if it then runs when pressing up
    regards
    Andy
  5. Re: Allroad suspension not lifting
    Jan 2013
    Skipton UK
    regards
    Andy
    Hi Andy, this is crucial advice. The Independent Garage who now have it have rung to say VAGCOM reporting an overheating issue and that the battery is knackered. So you are on the right lines. They are going to put a seal kit in the compressor and fit a new battery !! Probably too late to stop them doing the seal kit but will call to see if they can unplug the temp sensor first. Is it an obvious connection ? Regarding the question about it noticing you press the up button, the green light on the button comes on whilst it is pressed in but as soon as you release it the light goes out. Thanks
  6. Re: Allroad suspension not lifting
    Jan 2013
    Skipton UK
    Latest update is that compressor now running much better with new seal kit installed and only faults are temperature related so they swapping the sensor off the mechanics own Allroad to confirm. However, they are saying that you can't buy the sensor by itself. Any ideas if this is correct or where I might find one in a hurry ?? Thanks
  7. Re: Allroad suspension not lifting
    Ayrshire, Scotland
    18 Post(s)
    just unplug the temp sensor it will run without it for testing, and as long as you don't keep lifting it or playing with it will be fine without it for a short while,
    you can buy the temp sensor on its own from a german company, i also usually have some but i don't currently have any spare ones but I will have some available soon too
    best regards
    Andy
  8. Re: Allroad suspension not lifting
    Jan 2013
    Skipton UK
    Hi Andy,
    thanks for all your help with this !
    Assuming that disconnecting and or trying the sensor off the mechanics car fixes the problem I will try and convince them to leave theirs on my car until I can get them a replacement sensor from you.
    How long before you get one, how much, and do you want paying first ?
    PM me the details if you prefer
    Rupert
  9. Re: Allroad suspension not lifting
    Ayrshire, Scotland
    18 Post(s)
    Hi Rupert, Was it the temp sensor?
    ive now got some brand new ones in stock,
    i will PM you the details
    regards
    Andy
  10. Re: Allroad suspension not lifting
    Jun 2014
    Uckfield, East Sussex, UK
    regards
    Andy
    Hi Andy,
    Can you please advise if your refurb air compressors have this new temp sensor on? Can you also PM me the details of this sensor, including price?
    Thanks.
  1. Allroad Air Suspension
    By davidwills in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-09-2013, 10:26 PM
  2. Allroad Suspension Issues
    By Paul Mc Ternan in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-08-2010, 08:43 PM
  3. Allroad suspension
    By adamdavis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2009, 10:17 PM
  4. Allroad suspension
    By murdochcg in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-06-2009, 11:15 AM
  5. Allroad Suspension leak
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-02-2009, 07:58 PM
