Thread: Polo From Wipers Not Working - Odd One
Results 1 to 10 of 11
  1. Polo From Wipers Not Working - Odd One
    Jan 2009
    Got an odd one. when I start up the Polo in the morning, the wipers do not work right away. I have to wait a few minutes and when on Fast setting the wipers will then work in all settings. They generally are OK for most of the day.
    Any ideas why this happens please.
    OK 2002 Polo 52 plate 1.4
    John
  2. Re: Polo From Wipers Not Working - Odd One
    May 2007
    17 Post(s)
    Hi John, welcome to the forum.
    When you say the wipers don't work right, can you explain what are they doing?
    Jim.
  3. Re: Polo From Wipers Not Working - Odd One
    Jan 2009
    Hi Jim,
    When I start the car and I need to clear the screen. I put the wiper lever up and nothing happens, I move it to the slow setting and still nothing happens, I move it to the fast setting and still nothing happens. Then I move the level back down and try again. After a few minutes when I have moved the wiper lever up to fast, the wipers start in fast mode. I then move the level back down to slow and the wipers slow down as normal. I then drive to work, then later when I go home the wipers work as normal. It is not until the next morning that the wipers do not work again.
    Any ideas ?
    John
  4. Re: Polo From Wipers Not Working - Odd One
    Aug 2011
    Meath
    probably the relay is on its way out
  5. Re: Polo From Wipers Not Working - Odd One
    Jan 2009
    Hi What type pf relay? Can you advise part number of Polo 1.4 late 2002 plate 52
    John
  6. Re: Polo From Wipers Not Working - Odd One
    May 2007
    17 Post(s)
    John, the wiper relays on your car are built into the power supply control unit and can't be replaced. It could be the relays that are faulty but you'd want to be sure before replacing an expensive ECU. Can you hear the relays operating when you switch the wipers on? Even if you hear the relays operating, that doesn't mean they aren't faulty. Youd have to do a few checks with a voltmeter to check what's coming out of the ECU.
    Jim.
  7. Re: Polo From Wipers Not Working - Odd One
    Jan 2009
    Power Supply unit. Is this the one on top of the Battery ?
    POLO MK4 9N 2002-2005 ONBOARD SUPPLY CONTROL UNIT 6Q1937049D
    John
  8. Re: Polo From Wipers Not Working - Odd One
    May 2007
    17 Post(s)
    No, it's behind the dash on the driver's side.
  9. Re: Polo From Wipers Not Working - Odd One
    Jan 2009
    One thought I had also..... could it be the battery that may not be strong enough ? Just odd that it does not start until a few mins after starting the engine.
  10. Re: Polo From Wipers Not Working - Odd One
    May 2007
    17 Post(s)
    Quote Originally Posted by bigjohnuk View Post
    I doubt that John. If the battery was so bad that it couldn't power a wiper motor there is no way it be able to power the started motor. And once the engine has started the electrics are all supplied power from the alternator.
    The way it's working does sound a little strange as if something in the electronics of the supply ECU is charging up or something. It might be worth trying the old disconnect the battery trick (terminal 30 reset if you want to sound technical). Disconnect the neg battery terminal and touch the disconnected neg lead onto the positive battery terminal. That will discharge everything. It's easy and doesn't cost anything, so worth a try. And it's surprising how often it actually does fix things.
    Jim.
  1. Alarm not sounding and odd wipers!!!
    By Norm 71 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-12-2013, 09:21 AM
  2. Wipers not working -help please
    By kadul in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2011, 02:47 PM
  3. polo wipers not working
    By olly in forum Polo - Derby - Lupo - Fox
    Last Post: 07-01-2010, 02:51 PM
  4. VW polo 1.4 CL, Wipers stopped working
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 21-12-2009, 09:48 AM
  5. Polo Odd humming noise
    By theblackdeamon in forum Polo - Derby - Lupo - Fox
    Last Post: 05-11-2007, 11:25 PM
