Thread: Intermittent fault p0016
Results 1 to 8 of 8
  1. Intermittent fault p0016
    Oct 2014
    Newcastle upon Tyne
    2008 passat 2.0 tdi cr dpf , cbab engine. Intermittent fault ( crank shaft position camshaft position correlation bank 1 sensor 'A'.. Had the car 6 month the fault flashes up once sometimes twice a week , it's always in the 1st few minutes of the 1st time I use the car on that day . And it goes off as quick as it comes on . The car drives as it always has . Had it 2 vw main dealer and said it could be any of the sensors listed on the fault , the 1st 1 that they said to change would be the camshaft sensor @ £400 ( £50 for the part, 2 to 4 hrs labour ( poss have to drop the gear box to get 2 it ) and vat) but they said it might not fix it ! Just ask 2 see if any 1 has had the same problem and what was the fix
  2. Re: Intermittent fault p0016
    Aug 2011
    Meath
  3. Re: Intermittent fault p0016
    Norfolk
    Your car doesn't need both sensors to start. That is why you are ok. A vcds log will give a clue to what is causing the fault. Pity the dealer don't know that. You can ignore it if you want and wait for the car to get harder to start.
  4. Re: Intermittent fault p0016
    May 2007
    17 Post(s)
    Hello Stephen. The fault code means the synchronization of the crank & cam sensors signals is out. It's often caused by the timing belt not being set up properly.
    Has the engine had a timing belt done is is it perhaps due? Either way, I think it would be worth checking the timing of the engine is set correctly before spending £400 replacing sensors.
    Jim.
  5. Re: Intermittent fault p0016
    Oct 2014
    Newcastle upon Tyne
    Ok thanks . Yes the timing belt was done 3 months b4 I got the car it's only done 40 k and only done about 6 k since the belt was changed . I did a bit of research on the Internet and that's what came back the timing . But the vw garage said if it was the timing the car would run as good as it does .
  6. Re: Intermittent fault p0016
    May 2007
    17 Post(s)
    Quote Originally Posted by stephenseward View Post
    The VW garage may be correct, but I think checking the timing really has to be the first step in diagnosing the fault. Taking a £400 guess certainly isn't.
    If I was going to be condemning a £400 part on your car, I'd want some evidence that the part was faulty. Maybe connect an oscilloscope to the sensor and run the engine from cold to see it there was some anomaly on the sensor signal from cold that disappeared as the engine warmed up. Then I would be OK with taking your £400. That's the sort of thing your dealer should be doing, not just taking a stab in the dark and hoping for the best.
    Jim.
  7. Re: Intermittent fault p0016
    Norfolk
    005. Start Conditions (last Engine Start) This data block is only useful if you suspect crankshaft or camshaft sensor faults)
    1. Engine Speed,(G28), Idle 800
    2. Start Injection Quantity, 7.0...19.0 mg/Str.
    3. Start Synchronisation
    The value is the Sum of the individual Values below.
    001 = Self Synchronisation Camshaft active
    002 = Self Synchronisation Crankshaft active
    004 = Engine running
    008 = Engine Synchronisation validated
    016 = Engine Synchronisation successful
    032 = Self Synchronisation Camshaft-Sensor successful
    064 = Self Synchronisation Crankshaft-Sensor successful
    128 = First valid Tooth recognized
    Most successful starts register as 255. (255 = 128 + 64 + 32 etc).
    A failure of crank or cam sensor will cause a total with one or more numbers missing.
    Why the dealer cannot check this for you I do not know.
    1 1 0
  8. Re: Intermittent fault p0016
    Oct 2014
    Newcastle upon Tyne
    Got the car booked in at a different ( non main dealer ) garage next week to run the check again then check the timing .. Thanks for the reply's
  1. Question 1.4 TSI engine faults p0016/p2293 is this the Cam chain?
    By fredthedog in forum Golf MK5 - 2004 - 2009
    Last Post: 07-09-2014, 11:29 AM
  2. Question Touran Faults p0016/p2293 - Cam chain? (Same as Golf?)
    By fredthedog in forum Touran - Sharan - Caravelle
    Last Post: 04-09-2014, 09:03 PM
  3. Question poor idle speed 2004 1.6 sportback with fault code p0016
    By Malthouseroad in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-08-2014, 10:35 AM
  4. Question Intermittent fault
    By rswa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2014, 05:54 PM
  5. Intermittent Fault
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2013, 11:35 AM
