Thread: Parking Brake Malfunction
Results 1 to 10 of 10
  1. Parking Brake Malfunction
    Jul 2012
    United Kingdom
    So, I was parked up yesterday and engaged the handbrake and switched off the car. All good. I started the car up again after a few minutes and put the car into reserve and moved off which also disengages the hankbrake as per usual. Then a 'Parking Brake Malfunction' warning popped up on the DIS. I stopped, tried engaging the handbrake and it wouldn't enage. The red light on top of the switch to engage the handbrake just flashed.
    I stopped and started the car and everything looks good now. Any ideas what this could be as searching around most people have a permament problem (i.e handbrake does not engage again) but could not see anything where it only happened once (touch wood). Cars in for a service in a couple months so can get it scanned but wondering if anyone has similar issues?
    Ta,
  2. Re: Parking Brake Malfunction
    Ardfern
    8 Post(s)
    Something similar has happened to me, but on each occasion, it has quickly resolved without intervention next time car has been run.
    No fault codes apparent either! Keep fingers crossed that it is not a sign of impending doom!
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  3. Re: Parking Brake Malfunction
    May 2014
    United Kingdom
    I put a thread on recently with a similar issue where I get the same symptoms. Cycling the ignition clears the fault for a few months but i have a permanent ABS fault code on VCDS. The fault appears on the left side so I have switched the rear motors over to see if the fault goes to the right hand side. With my fault only one side engages and you can feel that in the way the car lurches to one side when applying the brake. Check out my thread.
    EPB fault..
    I will update it when the fault comes back. I suspect it may be the EPB module in the boot.
  4. Re: Parking Brake Malfunction
    Jul 2012
    United Kingdom
    Quote Originally Posted by Boy View Post
    Yeah, this is the first time it has happened I've owned the car (2 years). I'll see how it develops over the coming weeks.
  5. Re: Parking Brake Malfunction
    Jul 2012
    United Kingdom
    Quote Originally Posted by Gtfc14 View Post
    EPB fault..
    Hmm, I didn't notice only one side engaging. I'll have to check this out now but the warning light only came on after I drove off and then handbrake wouldn't engage at all (no motor noise). Maybe these could be different issues. I'll keep an eye on your thread to see what your resolution was.
  6. Re: Parking Brake Malfunction
    Jul 2012
    United Kingdom
    I've had the car scanned (with service) and there was a park brake electronic fault. I've been told the brake Caliper is the culprit and this will need to be changed. I'll wait for fault again and probably get this changed.
  7. Re: Parking Brake Malfunction
    May 2014
    United Kingdom
    Quote Originally Posted by _tones View Post
    Be careful. My fault codes showed parking brake motor on the passenger side so i swapped the motors over(took 10 mins) and waited for it to happen again.
    When it did happen again it was still on the passenger side and from what ive read it could be the button or parking brake module. I would strongly advise swapping the motors over to rule them out and stop you wasting cash on the wrong component.
  8. Re: Parking Brake Malfunction
    Jul 2012
    United Kingdom
    Hmm, I'm guessing you still haven't got to the bottom of the issue. I don't have the tools to switch the motors. I don't plan on changing the caliper until it reoccurs. Think cost with labour is around £400 so not a cheap 'fix'
  9. Re: Parking Brake Malfunction
    May 2014
    United Kingdom
    I think a motor(not full caliper) was around £200 and the module was around £220. I didnt pinpoint it just ruled out the motors. My clutch release bearing started screaming and rattling and the labour was 9 hours on the B8 as opposed to 3 hours on the previous B6/7 models so to change just the release bearing would have been risky given that the DMF and clutch are accessible with the gearbox out. The £1100 quote on top of the brake fault made me get rid of the car 2 weeks ago. The B8 has been very unreliable and i have gone back to a B7 which i had before.
    The motor change is a 10 minute job and you dont need to change the whole caliper. Might be worth mentioning that when you talk to the garage again.
    Good luck and i hope you get to the bottom of it first time.
  10. Re: Parking Brake Malfunction
    Jul 2012
    United Kingdom
    Yeah, I'll mention it when back in. I'll update on here when issue is resolved (whenever that may be :-))
  1. Please Help E-Parking Brake Malfunction
    By Avidfanofstuff in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-10-2013, 08:30 PM
  2. Electronic parking brake malfunction
    By philsteward in forum VCDS - Help Requests
    Last Post: 03-02-2012, 11:22 AM
  3. A8 parking brake malfunction
    By HIWEX in forum A8 - S8 - V8
    Last Post: 13-09-2011, 09:50 AM
  4. Parking brake malfunction
    By mannsy52 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-06-2011, 09:16 PM
  5. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
