Thread: Airbag problem
  1. Airbag problem
    Jan 2013
    Crowborough
    I recently retrofitted cruise control to my Cabriolet. This is all working well, but I am left with the airbag light on. I've reset this with VCDS but it comes straight back on. The 2 faults are:
    2 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    I have checked the connector in the steering wheel and tapped out the wires from the plug to the terminals on the back of the airbag which appear to be fine. Not sure what to look for now - any ideas? It seems odd both igniters are showing faults.
  2. Re: Airbag problem
    Jan 2013
    Crowborough
    All sorted - down to my stupidity - missed replacing one of the connectors under the steering column shroud - Doh!
  1. Question airbag problem a4
    By ruskie86 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-09-2014, 05:44 PM
  2. Caddy Airbag Problem !!!
    By __snake__ in forum VCDS - General Questions
    Last Post: 31-07-2010, 06:07 PM
  3. Airbag Problem
    By Hugo- in forum Golf MK5 - 2004 - 2009
    Last Post: 24-11-2009, 10:27 PM
  4. A6 Airbag problem
    By The gaffer in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-06-2009, 11:07 AM
  5. Airbag problem
    By twebbas in forum Audi A3 - Archive Topics
    Last Post: 22-09-2006, 09:04 AM
