Thread: Vacuum Unit - when is a vacuum pipe necessary?
Results 1 to 8 of 8
  1. Vacuum Unit - when is a vacuum pipe necessary?
    Jun 2013
    Portadown
    The charge pressure control solenoid valve (3) to the Non return valve (4) has a tube (7). In my car (Audi 2.5tdi BFC V6) the tube was cut and both cut ends tucked behind the fuel filter. I have replaced the cut tubes with one complete tube (consistent with the diagram).
    Does if matter? The non return valve side (4) was probably okay. Not as sure about the charge pressure control solenoid valve.
  2. Re: Vacuum Unit - when is a vacuum pipe necessary?
    130 Post(s)
    1972 Post(s)
    DO you mean the pipe to the air filter?
  3. Re: Vacuum Unit - when is a vacuum pipe necessary?
    Jun 2013
    Portadown
    No, the pipe to the air filter is number 2 in the diagram on the origional post. Its the tube from the non return valve (thats black and white and has to be fitted the correct way round) to the pressure control solenoid valve. Thats 3 and 4 on the diagram.
    Thanks for the interest
    G
  4. Re: Vacuum Unit - when is a vacuum pipe necessary?
    130 Post(s)
    1972 Post(s)
    Well I would say it must be a the diagram says, which year and engine code is your car? Does the N75 valve have a vacuum feed?
  5. Re: Vacuum Unit - when is a vacuum pipe necessary?
    Jun 2013
    Portadown
    Engine code BDG 2004, yes tube goes from the pressure control solenoid to the vacuum unit (tube 1 on diagram).
    Query comes from my surprise that someone would cut tube 7, and I wondered was there a rational reason and was I wise to repair it. It's a circuit that I don't really understand the principles.
    As you advise, if it's in the diagram - it must be right!
  6. Re: Vacuum Unit - when is a vacuum pipe necessary?
    130 Post(s)
    1972 Post(s)
    The one way valve allows the vacuum pump (6) to create a vacuum in the light grey line and this provides the N75 (3) and the N18 EGR solenoid with a strong vacuum, the one way valve prevents the vacuum pump allowing the depression to deplete when the engine is off. The N75 then uses this vacuum signal in a modulated on/off fashion to apply a vacuum to the turbo control diaphragm which alters the position of the internal vane ring and allows the engine ECU to position the ring exactly where it wants it to be according to the map in the memory. The other line from the N75 is the vent line for the N75 and the N18 and the go to the air filter in order to provide them with clean air without having to resort to a separate filter.
    1 Vacuum hose From EGR valve -N18- to mechanical EGR valve
    2 Mechanical exhaust gas recirculation valve
    3 To solenoid valve for charge pressure control -N75-
    4 Vent hose to air cleaner housing Depending on version
    5 Non-return valve Note installation position (light side/dark side) - as shown in illustration
    6 Brake servo
    7 Exhauster pump
    8 Exhaust gas recirculation valve -N18-
    9 To vacuum reservoir
    10 Throttle butterfly valve -N211- Depending on version
    11 To intake manifold flap Depending on version
    1 1 0
  7. Re: Vacuum Unit - when is a vacuum pipe necessary?
    Jun 2013
    Portadown
    Thanks for your advice. This is one of the final stages of an engine rebuild - few more parts to get and then its back on the road.
  8. Re: Vacuum Unit - when is a vacuum pipe necessary?
    130 Post(s)
    1972 Post(s)
    Ahh, someone else who can't sleep.......
  1. vacuum pipe attatched to servo pipe
    By deezal in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-06-2013, 04:55 PM
  2. What's this vacuum pipe?
    By Golf tdi Hal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-02-2013, 09:42 PM
  3. Vacuum pipe or not?
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2011, 03:47 PM
  4. Question Vacuum pipe connection
    By m3gadeth in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-11-2011, 12:15 AM
  5. Damaged vacuum(?) pipe
    By screamer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-05-2009, 07:38 PM
