Thread: Likely cost of a timing belt change?
Results 1 to 10 of 15
  1. Likely cost of a timing belt change?
    Oct 2013
    Hakadal, Norway
    Hi all
    My 1998 1.9 TDi (AFN) A4 is coming up for a timing belt change (3rd time). I could do it myself but it will probably be due midwinter when working outside is a no-no (here in Norway, -30degC and deep snow).
    Now the cost* here will be prohibitive so planning a trip over the border to Sweden (about 150 miles each way) to get it done but was wondering what a typical cost in the UK would be as could combine it with a mini-break and some xmas shopping.
    Would be for a timing belt, tensioners, water pump etc, drive in, drive out basis (I'd need to bring my own anti-freeze as the stuff you get in the UK just won't cut it here).
    Any info would be good.
    Stuart
    *(You wouldn't believe the costs here, parts can vary from double to ten times as much which is why most of mine are bought mail order from the EU as even with import duty and post office admin charges and getting the wrong stuff half the time it's still cheaper than buying local. Labour charge is £100 ph minimum for a back street garage)
  2. Re: Likely cost of a timing belt change?
    Mar 2008
    High Wycombe
    Timing belt change on a 1.9tdi with a water pump should cost around £300 over here. Might be a bit more to include the tensioner damper
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Likely cost of a timing belt change?
    Pembrokeshire
    22 Post(s)
    afn water pump is not driven off the timing belt so no need to touch it. the belt kit consists of a belt and tensioner. about the easiest ever audi to do, hardest part is getting the front into service position. about an hour to get the front off and back on, another 1.5 or so to do the belt.
    0 3 0
  4. Re: Likely cost of a timing belt change?
    Feb 2010
    Worcestershire UK
    I have to agree with the above comment by 'Zollaf'
    The AFN is a doddle to work on regarding the TB change. As a rule I usually check the Alternator freewheel and the state of the aux belt tensioner whilst doing a TB change. Any excessive corrosion on the tensioner will lead to a headache later on. Best to sort all the niggles at the same time. You might as well add new belts to your shopping list as, again this will save time and trouble later on. I enjoy working on the great little AFN engines. Have fun
    0 3 0
  5. Re: Likely cost of a timing belt change?
    Pembrokeshire
    22 Post(s)
    the 1z in my 80 is basically the same as the afn but you don't need to pull the front to do the belts. its about an hour for me, you just remove the fans to create space.
    1 2 0
  6. Re: Likely cost of a timing belt change?
    Feb 2010
    Worcestershire UK
    Quick question for you Zollaf, hope you don't mind. I've got to play with an 1974/5 Audi 80 Avant at some point in the near future, Timing belt, water pump and stat ect. I'm pretty sure I know how to do the job but it's been a very long time since I opened the bonnet on an 80! It's a V6 beast. I take it that the front end can be removed in a similar fashion to the A4 B5? This car is being returned to the road after ten years storage. It's in need of a fair bit of TLC. Then after that I have a lovely old 1981 90 5 cylinder 2.0 (I think) to do the same to. Such fun playing with REAL Audis
  7. Re: Likely cost of a timing belt change?
    Pembrokeshire
    22 Post(s)
    presuming you mean 94/95, then yes, the bumper comes off and the front goes into service position. you will need the locking plate that goes between the cams to do it properly, and the crank locking pin.really nice engines to do , same as my s4.
    1 1 0
  8. Re: Likely cost of a timing belt change?
    Feb 2010
    Worcestershire UK
    Oops Yes I did mean a 1994/5 not 74/75 My bad. Sorry 'bout that, Ive been renewing the petrol pipes on a 1974 100 GL that's what caused the confusion. That and the petrol fumes
    Thanks for taking the time to reply Zollaf. Sorry to the oP for taking the thread off course a little!
    0 2 0
  9. Re: Likely cost of a timing belt change?
    Oct 2013
    Hakadal, Norway
    Hi all,
    Thanks for all the info, tempted to do it myself now. I had the front into service position a couple of weeks back as had to replace the aux belt and tensioner so not too daunted by that, was actually pleasantly surprised as to how easy it was to do, especially as no idea how long its been since it was apart. Getting the fan pulley off was the main difficulty in order to remove the aux belt tensioner. The alternator freewheel seemed in good condition as well.
    I will price up what it will be in Sweden as well as its only a couple of hours drive and prices are much lower there as well. I got a quote from the Audi dealer here as well and was pleasantly surprised at £750 without water pump, perhaps pleasantly surprised is not correct but surprised it wasn't over the £1000.
    Stuart
  10. Re: Likely cost of a timing belt change?
    Pembrokeshire
    22 Post(s)
    for 750 quid i would be tempted to fly to you and do it
    1 2 0
  1. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  2. Cost of Major service & Timing belt change
    By Loofer in forum Chat - Anything with wheels
    Last Post: 08-10-2011, 01:56 PM
  3. Cost of cam belt change and service.
    By _Imran_ in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-06-2009, 12:28 PM
  4. cam belt change cost £800 !!??
    By sootyscottie in forum Audi A3 - Archive Topics
    Last Post: 21-11-2008, 08:04 PM
  5. mk 4 golf tdi 150 bhp.timing belt cost
    By motorhead in forum Golf MK4 - 1999 - 2004
    Last Post: 25-11-2007, 12:26 AM
