Thread: 2007 A6 "Check" button
  1. 2007 A6 "Check" button
    Jul 2014
    Lincoln
    My 2007 A6 has a "Check" button, which I think many (if not all do). I know that I can use it to set a speed warning and to bring up any faults if a warning light appears.
    However, when the ignition is on but the engine isn't, if I press it, it shows up some symbols in the driver display (between the speedo and rev counter) - some are red, some yellow. I don't get any warning messages though. Is that all normal or do I have any problems? I'm hoping it's all as should be.
  2. Re: 2007 A6 "Check" button
    Southern County Softy
    20 Post(s)
    It Just scrolls through all the systems it monitors. Sounds like yours is as it should be.
    When you first turn on the ignition it will go through the checks and give you an OK message if all is well.
    A4 2.5 tdi QS (mapped)
  3. Re: 2007 A6 "Check" button
    Jul 2014
    Lincoln
    Thanks. The manual is a big vague about it so I wanted to check. When I manually press the "Check" button it scrolls through but doesn't give an OK. But you say, when I switch the engine on normally it should say "OK" each time? I can't remember if it does or not but will check later.
  4. Re: 2007 A6 "Check" button
    20 Post(s)
    The A6 may be slightly different from my A4
  5. Re: 2007 A6 "Check" button
    Sep 2011
    Lurking over a keyboard ...
    On my A6 (2005) I don't get OK message at end, it just scrolls through tests and just finish if no faults.
    If there is a fault it will show in DIS on initial ignition key turn/detection, then will disappear from DIS after period and if you wish to re read it you press check button.
  6. Re: 2007 A6 "Check" button
    8 Post(s)
    On my earlier C5 A6 it jused to say ok but my C6 doesn't.
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  7. Re: 2007 A6 "Check" button
    46 Post(s)
    As above, if there is a fault the car will display it on the DIS without you doing anything. The function is working as normal.
  1. Replies: 24
    Last Post: 07-04-2016, 10:37 AM
  2. Golf MK4 - "Check brake pads" + Essex servicing?
    By bsdbm in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2009, 09:31 PM
  3. erratic temp guage and "check coolant" light problem
    By Hurley1611 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2009, 10:15 PM
  4. "Check" button
    By warped in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-12-2008, 10:30 AM
  5. Replies: 0
    Last Post: 30-03-2008, 02:46 PM
