Thread: ESP fault and A3 not starting
  1. ESP fault and A3 not starting
    Jun 2014
    A, A
    ]Hi Guys,
    I wonder if anybody could suggest what could be wrong with my Audi. I have an Audi A3 1.9TDI Sportback 2007. It is usually very reliable to start, that is until today.
    I went to start the car, waiting for the coil light to disappear on the dash before turning the ignition key, then nothing apart from a Click, click, click, click sound. The engine didn't even fire up. I was left with an ESP Fault, consult your manual on the dash. I did this and it didn't have any suggestions as to what it could be.
    Could anybody help and advise what they think might be the problem?
    Many thanks in anticipation
  2. Re: ESP fault and A3 not starting
    46 Post(s)
    Is the battery fully charged?
  3. Re: ESP fault and A3 not starting
    Jun 2014
    A, A
    The car started a couple of days ago, not sure how to check if the battery is fully charged, maybe I should try and jump start it? I tend to use it for fairly short journeys so maybe the battery is finally flat?
  4. Re: ESP fault and A3 not starting
    Southern County Softy
    20 Post(s)
    Charge the battery off the car then get it checked.
    If its the original battery I would change it.
    Sent from my GT-I9505 using Tapatalk
    A4 2.5 tdi QS (mapped)
  5. Re: ESP fault and A3 not starting
    Jun 2014
    A, A
    One new battery and everything's back working as normal. Thanks kite & Chris for your help
  6. Re: ESP fault and A3 not starting
    20 Post(s)
    Good to hear
  1. Dreaded ESP Fault DIS warning and G201 fault code
    By Daz6546 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-09-2015, 01:53 PM
  2. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  3. Poor starting and ESP light on
    By marcus gp1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-11-2013, 06:16 PM
  4. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    By rogerholmesuk in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2011, 09:03 PM
  5. Please Help Esp Light/hot Starting Issues
    By gazuk_1 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2008, 11:18 PM
