Thread: A6 Engine problems, please help
  1. Exclamation A6 Engine problems, please help
    Jun 2014
    Monterrey, Mexico
    Hi there. This is my first post after looking for the problem for weeks with no results. I really need help.
    I have a 2008 A6 Audi 2.8 FSI. Check Engine (MIL) turns on every few days, and I think it happens when day is too hot (near 40° Celcius). While reading to VCD codes I get the following Fault Codes:
    I can clear the codes but the first one (powertrain) always appear again immediatly after. After few days Check Engine (MIL) appears again with those "System too Rich" fault codes. Any ideas?
    Thank you in advance =)
    005748 - Powertrain Data Bus
    P1674 - 000 - Implausible Message from Instrument Cluster
    Freeze Frame
    Fault Status: 01101000
    Fault Priority: 4
    Fault Frequency: 92
    Reset counter: 40
    Mileage: 83277 km
    Time Indication: 0
    Date: 2014.06.04
    Time: 20:17:17
    Freeze Frame
    RPM: 832 /min
    Mass Air / Rev.: 169.0 mg/str
    Temperature: 31.5°C
    Idle
    Voltage: 13.26 V
    Speed: 0.0 km/h
    004407 - Fuel Trim: Bank 1 (Add)
    P1137 - 000 - System too Rich - Intermittent - MIL ON
    Freeze Frame
    Fault Status: 10100010
    Fault Priority: 6
    Fault Frequency: 6
    Reset counter: 40
    Mileage: 83458 km
    Time Indication: 0
    Date: 2014.06.07
    Time: 11:37:30
    Freeze Frame
    RPM: 736 /min
    Mass Air / Rev.: 136.3 mg/str
    Temperature: 99.0°C
    Idle
    Time: 1715.2 s
    Bin. Bits: 00000010
    004409 - Fuel Trim: Bank 2 (Add)
    P1139 - 000 - System too Rich - Intermittent
    Freeze Frame
    Fault Status: 00000010
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 38
    Mileage: 83458 km
    Time Indication: 0
    Date: 2014.06.07
    Time: 11:37:53
    Freeze Frame
    RPM: 736 /min
    Temperature: 99.0°C
    Idle
    Time: 1740.8 s
    Bin. Bits: 00000010
  2. Re: A6 Engine problems, please help
    46 Post(s)
  3. Re: A6 Engine problems, please help
    Jun 2014
    Monterrey, Mexico
    Thank you Chris.
    What do you suggest me to do before sensor replacement? I mean, I can try checking MAF values or Oxigen Sensor values I think, but not sure how to do. First, MAF is not present in my car, it has a MAP so I can't see mg/sec values but mbar values. If you have some additional information I would be so glad with you. This malfunctions seem to be so random and appear every few days.
    Thanks!
  4. Re: A6 Engine problems, please help
    Nov 2012
    Somerset UK
    Just a thought but if your car has an EGR valve have you tried to change it or clean it if possible? I know that this can affect cars fitted with MAPS.
  5. Re: A6 Engine problems, please help
    Jun 2014
    Monterrey, Mexico
    Thank you very much Mark! I will try this when the engine gets cooler, as I wasn't able to find it (the valve).
    I did the following excercise:
    I turned on the engine and let it run idle for some minutes, no acceleration, 700~800 rpm. Lambda control values started from -10% both banks and started dropping within time to -35% bank 1 and -30% bank 2. Is this normal?
  6. Re: A6 Engine problems, please help
    Jul 2013
    76 Post(s)
    This explains the fuel trims
    Your car is a petrol so may not have an EGR valve.
    Check your vacuum pipes for leaks and check the air intake is not loose as could be sucking in air and the O2 sensor' s will compensate by adding more fuel.
    Dan
  7. Re: A6 Engine problems, please help
    Nov 2012
    Somerset UK
    Dan, you are right was getting EGR confused with a PCV valve, which are fitted to petrol engines almost exclusively. All of the petrol engines I've known have had Positive Crankcase Ventilation. Just got my TLA's mixed up
  1. Help: A3 seems to have engine problems
    By grain in forum Chat - Anything with wheels
    Last Post: 03-10-2008, 08:34 PM
  2. Please Help 1.8t engine problems
    By novacav in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2008, 12:39 AM
  3. Engine problems
    By welshwizard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-07-2008, 10:08 PM
  4. Problems with engine
    By midster in forum Archive posts
    Last Post: 28-07-2007, 04:32 PM
  5. !.8t engine problems
    By vw1.8turbo in forum Archive posts
    Last Post: 27-05-2006, 07:26 PM
