Thread: Parking sensors not working ? Please help
  1. Parking sensors not working ? Please help
    Feb 2013
    Uk
    38 Post(s)
    Today ,
    loss of parking sensors
    put car in reverse, and there was long beep for a few seconds and the diode in the "P" switch started flashing , the graphic image of the car did not show up in the colour mmi screen and the sensors do not work.
    All sensors in bumpers front and back are clean.
    i have reset the MMI system , and this has not solved the problem.
    Any one encounter this before ?
  2. Re: Parking sensors not working ? Please help
    46 Post(s)
    dead sensor possibly, or dead control unit. get a scan done, easiest way of solving it.
  3. Re: Parking sensors not working ? Please help
    Feb 2013
    Uk
    38 Post(s)
    Cheers chris ,thought a scan would be the case, will have to go to a garage and get a scan done ,
    Btw , just pulled the fuse , fuse ok , put fuse back in pressed "P" button graphic display cAme up , but no sound when walking close to. Bumpers !
    Pressed "P" button to cancel parking system , then pressed "P" again , no display this time and diode flashing in "P" button
  4. Re: Parking sensors not working ? Please help
    Feb 2013
    Uk
    38 Post(s)
    Hi chris ,
    just parked car up for the night , and the sensors and graphic display are now fully working , when reversing car
    Also manually turned the sensors off and on a few times when car was stationary , senses and display still working
    Dont get how it can suddenly start working again ?
  5. Re: Parking sensors not working ? Please help
    Jan 2012
    Coding Something
    I do wonder if some contacts have got bad conductivity & got a little damp, needs a scan to show historical faults as it may present again.
  6. Re: Parking sensors not working ? Please help
    Feb 2014
    Southsea, Portsmouth.
    Hi Q7, I had an intermittent sensor problem on my A6 Avant that presented similarly. I read somewhere on here that if you listen to the sensors they emit a click when they are working. I was able to identify the failed one and bought a replacement on eBay for £20 or so. I've not fitted it yet as the problem had cured itself since the weather improved.
    What I can't remember is the safe way to put the car in reverse so as to listen. I think I put the car in reverse and switched off the engine leaving the ignition on.
    If in doubt get a scan done.
  7. Re: Parking sensors not working ? Please help
    Feb 2013
    Uk
    38 Post(s)
    Thanks for the info , will use your method and post findings
    cheers
  1. Rear parking sensors not working
    By monz87 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-06-2019, 01:24 PM
  2. Parking sensors not always working
    By Little_Legs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2011, 08:52 PM
  3. Rear parking sensors have stopped working...
    By Saulmac in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-11-2011, 05:32 PM
  4. parking sensors not working
    By Bizzie in forum Octavia
    Last Post: 24-12-2010, 09:36 PM
  5. Please Help Sharan Parking Sensors no working
    By Burg in forum Touran - Sharan - Caravelle
    Last Post: 21-02-2010, 08:09 PM
