Thread: Tyre Pressures
  1. Tyre Pressures
    Nov 2013
    In the A6 manual with regard to tyre pressures it states on page 230 "The tyre pressure must be adjusted according to the load the vehicle is carrying. We recommend adhering to the tyre pressure specifications for a maximum load. However, if you prefer an extra-smooth ride and the vehicle is not fully loaded, you can select the tyre pressure for a normal load (no more than three people travelling in the vehicle). Should you wish to drive with a full load, you must increase the tyre pressure to the specified maximum.
    For my S-line with the 245/45R18 tyres the label on the driver's door states :-
    1 to 3 people 32psi Front and 30psi Rear
    1 to 5 people 35psi Front and 38psi Rear.
    These two sentences seem a bit contradictory "The tyre pressure must be adjusted according to the load the vehicle is carrying. We recommend adhering to the tyre pressure specifications for a maximum load." I just wondered if anyone does drive all the time with the tyres at maximum load pressure as recommended in the manual by Audi if like me there is only normally one or two adults in the car. The S-line ride is quite firm as it is and I would have thought even firmer at maximum load pressures when the car is not actually fully loaded.
  2. Re: Tyre Pressures
    Sep 2008
    No, as it's mainly just me and sometimes my wife in the car I use the lower pressures. If going away and have some luggage in the car I'll increase the rear pressure a bit.
    Can't see the point in increasing the front tyre pressures really as the load won't increase much on those.
    If fully loaded use the higher pressures but otherwise you wouldn't want to be driving around like that all the time.
    2014 Samoa Orange TT Roadster 2.0 TFSI Black Edition & 2015 Petrol Blue Skoda Yeti 2.0 TDI ~ Now Gone - 2013 Daytona Grey A6 Avant 2.0 TDI Multitronic Black Edition
  3. Re: Tyre Pressures
    Apr 2009
    Surrey
    178 Post(s)
    Quote Originally Posted by JannerAudi View Post
    The recommendation to use the higher pressures may of course be to do with the CO2 emissions rating they have managed to achieve. Higher pressures will lead to reduced rolling resistance and thus better fuel consumption, at the expense of ride comfort and also (when carrying less weight) poorer grip. By recommending them they can claim that all cars are like that and get the rating, even if drivers ultimately actually reduce the pressures
  1. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  2. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
  3. Tyre Pressures
    By dandam in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-04-2009, 11:16 AM
  4. Tyre Pressures
    By james_tiger_woo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2008, 09:15 AM
  5. t5 tyre pressures ???
    By paul600rr in forum The Commercial Range
    Last Post: 22-06-2007, 04:48 PM
