Thread: Litres per Hour Conversion
  1. Litres per Hour Conversion
    Related to my previous post, in the measuring block the mileage is noted in l/h, which I assume is litres per hour, I have had a look on the internet and can only find l/100km.
    Does anybody know a quick conversion between 1/h and mpg?
    Thanks.
  2. Re: Litres per Hour Conversion
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    Let's say the instantaneous l/h figure is X and at the same time the speed is Y mph. Then by my logic the instantaneous consumption will be:
    4.54609*Y/X mpg.
  3. Re: Litres per Hour Conversion
    Quote Originally Posted by 32110 View Post
    4.54609*Y/X mpg.
    Thank you for that.
    A further problem is the the speed is quoted in Km/h ( is there a way to get vcds to imperial?) so the conversion to mph with have to be integrated into your equation
    1 mp/h= 1.609 kmh or
    1 km/h = 0.621 mph
    Then y(kmh x 0.621 mph) x (x l/h / 4.56 l/h) = mpg
    So a practical example from one of my readings where
    y = 57.6 km/h
    x = 2.81 l/h
    mph(57.6km/h / 1.61km/h) X xg(2.81l/h / 4.56l/h) ===> 35.78mph x 0.618g = 22.11 mphg
    Or about 22.11 mpg (I think)
    Basically a bit of a to do to get there.
    People my find this link useful:
    http://www.convert-me.com/en/convert...iter_hour.html
  4. Re: Litres per Hour Conversion
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    Not sure that your equations are quite right.
    Speed = Z km/h = 1.609*Y mph or Y mph= 0.621 * Z kph
    So replacing Y in my equation with Z * 0.621:
    4.54609*Z*0.621/X mpg
    2.823*Z/X mpg
    So for your example:
    2.823*57.6/2.81 = 57.87 mpg
    Was your speed fairly steady at time of measurement?
  5. Talking Re: Litres per Hour Conversion
    I was doing around 30 mph, but I used a 'snap shot from vcds. I do drive an audi A4 B5 1996, if I'm getting nearly 60 mph at 30 mph I'll take that any day.
    As you can tell I'm hopeless at maths and you are probably right, but 57.87mpg seems a bit too good unless of course at that instant I had just taken my foot of the accelerator!!.
  6. Re: Litres per Hour Conversion
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    If you have a continuous output from VCDS then you could load into a spread sheet and get it to repeat the calculation and plot graph of output.
  1. 5 litres of water
    By PHASTAZPHUK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2012, 03:01 AM
  2. How many litres of oil in 2.0 TDI?
    By giggsy07 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-01-2012, 09:43 PM
  3. 3 litres Quattro cylinder layout?
    By tyreos in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-08-2009, 12:48 PM
  4. 3.0 Drunk over 7 litres of oil!
    By toff in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-04-2009, 11:15 AM
  5. andys A4 2.o litres turbs
    By andy.b.090206 in forum New Member Introductions
    Last Post: 03-02-2008, 11:06 PM
