Thread: clutch replacement cost 1.9 b6 estate
  1. clutch replacement cost 1.9 b6 estate
    derbyshire
    hi all, clutch started to slip slightly today, if you have had a replacement clutch on a 1.9 diesel passsat what did it cost and who did you get to do it,
    would you attempt this your self or get a garage to sort it
    i have been looking for quotes to replace the clutch + flywheel
  2. Re: clutch replacement cost 1.9 b6 estate
    Apr 2010
    uk
    somewhere between £700 & £800 for clutch, flywheel & slave cylinder but that was two or three years ago, a good one man band did it for me but too far north to travel.
  3. Re: clutch replacement cost 1.9 b6 estate
    Oct 2012
    Cardiff, Wales
    Why not have a go yourself if you are fairly handy with mechanics. Parts will probably set you back £350-£400. Not the easiest job but doable.
  4. Re: clutch replacement cost 1.9 b6 estate
    derbyshire
    Quote Originally Posted by A3_130 View Post
    hi i think thats the best option but i can see that its going to be a pain in the a***
    i have rang 3 people who specialise in clutches, prices range from 275 to 400 for just a clutch and 580 to 650 if it needs a flywheel.
    it runs really quiet ( for a diesel) so i dont think it needs a flywheel, but who knows.
    i was towing when it started to slip so went out today and no slip when not towing, however i need a car to to tow a caravan so i have to get this sorted.
    i am thinking at worst, new sachs clutch + flywheel 300 and a few bit and bobs so 350 for the parts
    at least i know its got decent parts in it.
    will post again.
    my mates advice was - sell it on
  5. Re: clutch replacement cost 1.9 b6 estate
    Jul 2013
    SE
    Paid 280 for clutch kit and 100 for changing it.
    jaraz
    VCDS / VAG COM -SE & E & Central London - Kent
    Oo w oO | Oo w oO
  6. Re: clutch replacement cost 1.9 b6 estate
    Norfolk
    Changing the clutch dmf etc on a B6 Passat is fairly simple nuts and bolts job. Time consuming but not difficult at all.
  1. Cost of replacement clutch and Dual Mass Flywheel (2.0TDI)
    By rufus2005 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-08-2018, 09:47 AM
  2. Question Heavy clutch on 2.4 SE - Any ideas on replacement cost?
    By hardenpeter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2011, 08:17 PM
  3. Fan replacement cost?
    By TASR12 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-09-2009, 11:50 PM
  4. Cost of headlight replacement
    By Stuart W in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-02-2009, 11:46 PM
  5. Cost of clutch replacement
    By Canetoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2007, 09:29 AM
