Thread: Can't delete SERVICE DUE.
  1. Can't delete SERVICE DUE.
    Jan 2011
    Stafford, UK
    Tried three times to reset SRI.
    List of faults before deleating them.
    Monday,31,March,2014,09:48:33:31033
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: xxxxxxxxxxxxx License Plate: 31-3-2014 1
    Mileage: 58170km-36145mi Repair Order:
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000100622308
    Coding: 011F06205C41410001
    Shop #: WSC 02391 823 56573
    VCID: 458B7E0ECCD8DF36E81-8010
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 58046 km
    Time Indication: 0
    Date: 2014.03.18
    Time: 10:23:28
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 652 A HW: 4E0 035 652
    Component: B-BN-EU H47 0048
    Revision: -------- Serial number: 349A-097506098
    Coding: 010101010102C3FD43000F0DEF7300030001
    Shop #: WSC 00779 210 97010
    VCID: 1F47CC660EC4E5E682D-804A
    Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
    Component: DU6 Basic H43 0306
    Subsystem 2 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
    Component: Bedienteil MM H01 0060
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 73
    Mileage: 57860 km
    Time Indication: 0
    Date: 2014.02.27
    Time: 09:33:26
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00000101
    List of fault codes after deleating.
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 85
    Mileage: 58179 km
    Time Indication: 0
    Date: 2014.03.31
    Time: 08:57:00
    Freeze Frame:
    After performing RESET I get.
    Monday,24,March,2014,09:25:35:31033
    Performed SRI & these are the results, showing SRI compleated OK. BUT the DIS stil showes SERVICE DUE, WHY ?
    VCDS Release 12.12.2: SRI Reset
    Control Module Part Number: 4F0 920 983 B Labels: 4F0-920-xxx-17.clb
    Component:KOMBIINSTR. H06 0135, Coding:2F57110502002700010401
    Operation: Please select an operation
    Channel Description
    Unit Current val. New val.
    02 Service Reminder Status 2 ---
    40 Distance since Service km x100 27 ---
    41 Time since Service Days 365 ---
    42 Minimum Distance to Service km x100 90 ---
    43 Maximum Distance to Service km x100 306 ---
    44 Maximum Time to Service Days 730 ---
    45 Oil Quality 1 ---
    47 Soot Quantity DIST x100 50 ---
    48 Thermal Load DIST x100 41 ---
    49 Minimum Time to Service Days 730 ---
    50 Basic Distance Value for Oil Change km x100 150 ---
    51 Basic Time Value for Oil Change Days 365 ---
    52 Basic Distance Value for Inspection km x100 152 ---
    53 Distance since Inspection km x100 28 ---
    54 Basic Time Value for Inspection Days 365 ---
    55 Time since Inspection Days 370 ---
    56 Day Counter Days 1882 ---
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  2. Re: Can't deleat SERVICE DUE.
    46 Post(s)
    Is it the oil or interval needing reset?
    You can reset the Oil from the MMI, CAR -> Service Interval Display then scroll down.
  3. Re: Can't deleat SERVICE DUE.
    Jan 2011
    Stafford, UK
    I changed the oil/filter then tried to reset service due in the DIS
    The service interval was set at 365 days.
  4. Re: Can't deleat SERVICE DUE.
    46 Post(s)
    Yes but what is the MMI saying, is it saying oil or inspection needs reset?
  5. Re: Can't deleat SERVICE DUE.
    Jan 2011
    Stafford, UK
    For some reason Chris the items in grey are unselectable.
  1. Question Service due
    By DwangersAQ in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-10-2011, 09:01 AM
  2. 'Service Due!' - Already? :S
    By Guest 2 in forum VCDS - Help Requests
    Last Post: 04-06-2011, 04:49 AM
  3. Service due
    By peza82 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-05-2010, 03:27 PM
  4. Service Indicator (When is next service due)
    By kenny1001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2008, 04:45 PM
