Thread: A6 2.0tdi fault P0405 help!
  1. A6 2.0tdi fault P0405 help!
    Nov 2013
    Glasgow
    Hi folks I'm looking for anyone that has had any dealings with this fault code
    P0405 exhaust gas recirculating senior A circuit low
    I have recently replaced the EGR valve and the car has been running faultless for the last 1000 miles . The car spears to be running and driving perfectly, no lack in power or boosting problems.
    I am stumped guys!!
    Help!
  2. Re: A6 2.0tdi fault P0405 help!
    46 Post(s)
    Is your engine light on?
  3. Re: A6 2.0tdi fault P0405 help!
    Nov 2013
    Glasgow
    Sorry Chris prob should have put this in....
    The engine management light is on and the coil pack light is flashing.
    I cleared the code but the coil light continued to flash, after driving the car for a short time the engine management light came back on
  4. Re: A6 2.0tdi fault P0405 help!
    46 Post(s)
    Could you get a scan with VCDS? What did you use?
  5. Re: A6 2.0tdi fault P0405 help!
    Nov 2013
    Glasgow
    I used a autel reader matey
  6. Re: A6 2.0tdi fault P0405 help!
    46 Post(s)
    Try and get it scanned with VCDS if you can.
  7. Re: A6 2.0tdi fault P0405 help!
    Jul 2013
    76 Post(s)
    What year is your A6 and engine code?
    That fault code means one of the following:
    1. the EGR wiring is shorting to earth.
    2. the EGR position sensor is faulty (this is built into the EGR, if your replacement one is ok then rule this out).
    3. The ECU is faulty.
    Dan
  1. 3.0tdi manifold fault
    By sparker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-09-2015, 10:12 AM
  2. Please Help A4 b8 2.0tdi fault codes - help!
    By chrisroffey in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-02-2014, 10:40 PM
  3. 3.0Tdi - P0183 fault code
    By seventh-heaven in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-09-2011, 11:12 PM
  4. Exhaust emmision fault code 2.0tdi
    By ralmeyda in forum Golf MK5 - 2004 - 2009
    Last Post: 16-08-2009, 12:54 PM
  5. intermittent fault on my 03 2.0TDi
    By 2pt joe in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-06-2009, 07:55 PM
