Thread: syphon fuel
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. syphon fuel
    midlands
    i have just filled up with diesel,
    but i have just had a call to say my new car has arrive a month early, can i syphon out the diesel?
    if not is there another way?
    i'm not sending it in with £70 worth of diesel in it.
    cheers
    NEW 2012 Golf mk6 1.6 tdi Bluemotion..tinted glass, white
  2. Re: syphon fuel
    Ask the dealer to tank your new car with the same amount of fuel?
  3. Re: syphon fuel
    midlands
    Quote Originally Posted by Eshrules View Post
    I would but I have a full tank of fuel as part of the deal
  4. Re: syphon fuel
    Pembrokeshire
    22 Post(s)
    lift bonnet, locate fuel filter. remove outlet pipe and connect a pump to the filter. switch on pump and allow it to draw the fuel from the tank through the filter and into cans. you will need the 5 litre plastic cans, 12 of them, or 4 ex mil jerry cans. don't get caught now as its illegal to have more than a certain amount of fuel in cans no bigger than 10 (???) litres. when finished, reconnect pipes and jobs done.
    personally i would just delay collecting the new car until you have used most of the new fuel.
  5. Re: syphon fuel
    Oct 2005
    Drive all the way there in 1st with your foot flat on the floor?
  6. Re: syphon fuel
    midlands
    No pump, so my have to try syphoning, or is an anti-syphoning devise fitted?
  7. Re: syphon fuel
    Feb 2014
    West Sussex
    most cars have an antisyphon blocker in the tank so good luck with that
    You don't need pump just switch on the ignition and let the car do the rest - be careful not to run it dry thought
  8. Re: syphon fuel
    midlands
    Quote Originally Posted by mjhamilton View Post
    ok thanks
  9. Re: syphon fuel
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Even if you have enough fuel cans to store this diesel you can't run fuel pump by just turning the ignition on, you need VAG-COM\VCDS.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  10. Re: syphon fuel
    Feb 2014
    West Sussex
    Quote Originally Posted by Keithuk View Post
    Depends on the car
    If I disconnect my fuel line and turn the ignition to on (don't need to start) things will get very wet and very dangerous pretty quickly
    Audi TT Roadster S-Line Quattro in Daytona Grey
    New, shiny and still topless
  1. Replies: 6
    Last Post: 19-12-2013, 11:02 PM
  2. Can you syphon out of the fuel tank 3.0TDi
    By MarkTM in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2013, 10:02 AM
  3. Replies: 3
    Last Post: 05-08-2012, 04:59 PM
  4. Question 1995 Golf VR6 fuel guage not working + fuel filter location
    By damo1982 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-06-2008, 10:04 PM
