Thread: 008583 - Bank 1 System too Lean at Idle
Results 1 to 8 of 8
  1. 008583 - Bank 1 System too Lean at Idle
    Aug 2013
    London
    I have been on the board but didnt posted much but browsed heavily. i had engine light turning on and then turned off after few cycles, was more persistent when AC was on, checked with OBD II it showed 0171 code. It has come back on and this time its not going back at all. asked a friend to scan vcds and it has come up with the following. on bit of research, it looks PCV but I am not sure, so any suggestions will be of great help. I have looked around vacuum pipes, didnt find any obvious leak.
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 4F2 910 115 B HW: 4F2 907 115
    Component: 2.0l R4/4V TFSI 0040
    Revision: --H14--- Serial number:
    Coding: 0105000302070120
    Shop #: WSC 00359 210 91468
    VCID: 1F4D05F7CE4807E68D9-804A
    3 Faults Found:
    008583 - Bank 1; System too Lean at Idle
    P2187 - 004 - - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 82461 km
    Time Indication: 0
    Date: 2014.03.15
    Time: 17:59:35
    Freeze Frame:
    RPM: 833 /min
    Load: 24.7 %
    Speed: 7.0 km/h
    Temperature: 64.0°C
    Temperature: 18.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.589 V
    008825 - Leak in Air Intake System
    P2279 - 002 -
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 82495 km
    Time Indication: 0
    Date: 2014.03.19
    Time: 19:40:57
    Freeze Frame:
    RPM: 779 /min
    Load: 14.1 %
    Speed: 0.0 km/h
    Temperature: 88.0°C
    Temperature: 45.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 13.970 V
    001287 - Idle Control System RPM
    P0507 - 001 - Higher than Expected. - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 82498 km
    Time Indication: 0
    Date: 2014.03.19
    Time: 19:45:53
    Freeze Frame:
    RPM: 899 /min
    Load: 14.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 44.0°C
    Voltage: 13.970 V
    2007 Audi A6 2.0T FSI
  2. Re: 008583 - Bank 1 System too Lean at Idle
    Nov 2012
    Somerset UK
    Why not simply google each of the faults?
    First one:
    18619/P2187/008583 - Ross-Tech Wiki
    Simples!
  3. Re: 008583 - Bank 1 System too Lean at Idle
    46 Post(s)
    Quote Originally Posted by MarkTM View Post
    First one:
    Simples!
    Not sure why people don't google the fault code first of all
  4. Re: 008583 - Bank 1 System too Lean at Idle
    Aug 2013
    London
    Thanks guys, I have already done that and posted for suggestion where to start first, though i missed this last line in special notes (If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.) check it indeed its the case with my a6. is 06F129101N the correct for this valve?
    18619/P2187/008583 - Bank 1; System too Lean at Idle
    Possible Causes
    • Injectors leak/blocked
    • Air Intake Leak (after MAF)
    • Exhaust Leak
    Possible Solutions
    • Check Mass Air Flow Sensor (G70)
    • Check Injector(s)
    • Check Fuel Pump
    • Check Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    Special Notes
    • When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
      • If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
  5. Re: 008583 - Bank 1 System too Lean at Idle
    Nov 2012
    Somerset UK
    GENUINE VW & AUDI 2.0T FSI PETROL PCV PRESSURE CONTROL VALVE 06F129101R | eBay
    Says it's for a 2009+ though.
    To be sure your best speaking to n Audi dealer tomorrow.
  6. Re: 008583 - Bank 1 System too Lean at Idle
    Aug 2013
    London
    spoken to local Audi dealer, they didnt have in stock, ordered for tomorrow along with the gasket as i think it make sense to change that too. both costing in total of 58 quids!
  7. Re: 008583 - Bank 1 System too Lean at Idle
    Aug 2013
    London
    fitted yesterday evening, the old valve was C version, it wasnt completely broken but wasnt working properly and loosing air even at closed position.
    Gasket
    PCV part num: 06F129101 N
    New and Old side by side before installation
    the old one has revision C
    engine cap removal while idling now have normal vacuum pressure which was crazy with old valve and required good effort to remove it. cleared faults codes, rescanned after test drive, was error free. The mother in law (MIL) hasnt come back yet after 1 day of driving and car is idling nice and smooth now.
    Before clearing the codes, i removed the oil cap it didnt take force but after removal engine started shaking think its normal, correct me if I am wrong, I havent checked after clearing the codes though.
    1 1 0
  8. Re: 008583 - Bank 1 System too Lean at Idle
    Aug 2013
    London
    after few days of driving, its all fine fingers crossed! good that found the solution spot on, seen people going from plugs, coils, MAF sensors etc first without solving this p0171 bank 1 too lean problem!
    A6 got its power and mileage is now much better.
  1. Question Fuel trim bank to lean
    By tezread in forum A8 - S8 - V8
    Last Post: 28-09-2013, 09:00 AM
  2. Audi 1.8T Fuel Trim: Bank 1 (Mult): System too Lean
    By RedZed2009 in forum VCDS - Help Requests
    Last Post: 03-07-2010, 02:50 PM
  3. Please Help Fuel Trim: Bank 1 (Mult): System too Lean
    By Phil2112 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2009, 03:05 PM
  4. Fault code P1128- 'Long Term Fuel Trim - System Too Lean Bank 1
    By bassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-05-2008, 09:56 AM
  5. A6 1.8T Sport. Fault Code P1136 Bank 1 Long Term Fuel System Too Lean
    By anthonyjparker in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-11-2007, 03:33 PM
