Thread: A4 tdi p2015 fault code
  1. A4 tdi p2015 fault code
    I've bought a 2008 audi a4 tdi from a friend that has a p2015 fault code on it. It also has the engine management like on but drives ok.
    He had it to a garage and they were surprised to fix it but haven't.
    It looks like they fitted a new throttle body.
    Any ideas on this problem??
  2. Re: A4 tdi p2015 fault code
    46 Post(s)
    18447/P2015/008213 - Ross-Tech Wiki
    18447/P2015/008213 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Power Loss
    Possible Causes
    Intake Manifold Flap faulty
    Intake Manifold Flap Motor (V157) stuck/faulty
    Engine Control Module Software/Firmware Version faulty
    Wiring and/or Connector(s) from/to Intake Manifold Flap Motor (V157) faulty
    Possible Solutions
    Check Intake Manifold Flap
    Check/Replace Intake Manifold Flap Motor (V157)
    Perform Output Tests/Basic Setting
    Check Wiring and/or Connector(s) from/to Intake Manifold Flap Motor (V157)
    Special Notes
    In some Cases the Issue can only be resolved by Replacing the whole Intake Manifold.
    The Intake Manifold Flap Motor (V157) and Manifold Runner Position Sensor (G336) may be Part of the same Unit.
    When found in a VW Golf/Jetta (1K): 1.9l PD-TDI (BRM), check Engine Control Module (ECM) Software Version:
    03G-906-016-AB @ 7328 or 7550 as well as 03G-906-016-AC @ 7280 or 7551 do have a Software Error which requires a special Adaptation for the Intake Manifold Flap Motor (V157) which at this Point can only be performed with the Factory Tool.
  3. Re: A4 tdi p2015 fault code
    Where abouts is the flap in the manifold?
    Is there any pictures available of the flap and motor?
    Is it what looks like a throttle body or is it inside the manifold it self?
  4. Re: A4 tdi p2015 fault code
    Jan 2014
    Athlone town rep of ireland
    I've just replaced this exact part on my b8 cost me €435 euros for the part from Audi like yours emissions light on but no loss in power car drove perfectly seems to be the little square bit at the end the sensor that goes in them common enough I think as that was the second one they had sold that day and the parts guy correctly guessed an 08 car maybe this was sorted on later years
  5. Re: A4 tdi p2015 fault code
    Jan 2014
    This sounds the same as I fault I had with MY2008 A4 TDI a few months ago but in my case there was a marked reduction in power
    The fault was diagnosed by my local dealer to be V157 intake manifold flap motor.
    The motor was replaced at a cost of £457.52.
    Before - 2008 A4 2.0 TDI SE 143 PS Silver
    Before - 2014 A4 2.0 TDI 150 PS BE in Phantom Black, Tech Pack
    Present - VW Tiguan R-Line 150 PS in Deep Black Pearl
  6. Re: A4 tdi p2015 fault code
    It could have already had a motor fitted??
    This is the new part
  1. Fault code 379 on A4 2.0 TDI B7
    By Andy_Pigott@msn in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-11-2011, 07:04 PM
  2. Fault code 18047 Passat tdi
    By Mark Redman in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 13-05-2010, 11:34 PM
  3. Fault Code Equipment for 06 Octavia 2.0 TDI
    By PeterFC in forum Octavia
    Last Post: 10-01-2010, 05:32 PM
  4. A4 2000 1.9 TDI Airbag Fault Code
    By Boy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2008, 08:23 PM
