Thread: Audi A6 2.0 TDI 10/2006 c6 change battery
Results 1 to 10 of 15
  1. Audi A6 2.0 TDI 10/2006 c6 change battery
    Dec 2013
    cyprus
    Dear all,
    I have an AUDI A6 C6 2.0 TDI Multritronic 10/2006. In the last start I observed that the power of battery is too low, also on driving I observed some strange things, on gear box, on power etc.
    (1) is this normal? when a battery has not good power BUT the car started to be the car like this?
    (2) the car has a 95Ah VARTA battery...can I charge it when it is connected to the car? OR I must remove it? I tried to remove it and the alarm activated??
    (3) If i replace the battery with 90Ah or 100 Ah battery has any problem? OR I must find the 95Ah battery?
    (4) if i replace it, may I do anything on the system of car or it will be normal from the first minute?
    I appreciated if you can help me in these 4 questions
    thanks a lot
    best regards
  2. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    46 Post(s)
    Did you do a search? This topic comes up pretty frequent. Try 'battery' and sect this section to search from.
  3. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    Dec 2013
    cyprus
    hi and thanks for ur reply. unfortunately i did not find to forum the information of rhe questions i sm looking. your help is much appreciated
    thanks again
  4. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    46 Post(s)
    0 2 0
  5. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    Dec 2013
    cyprus
    hi, the posts are useful and realy thanks. Unforunately what I want to know exactly I did not take it. So could you please reply in my questions? Your help is much appreciated.
    regards
  6. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    Jun 2006
    OK what are the symptoms you are noticing, how do you know the battery has low power, and what is happening with the gearbox etc?
    I would get a full VCDS code scan as this is the best way to know what is going on with all such systems on the car.
    If it is your battery, and it's old and failing, rather than not getting charged properly, then personally I would replace like with like, so a 95AH battery.
    If you change it for another type, then you will need to re-code the battery manager, so that it can ensure the battery is properly charged.
    To charge the existing battery, you must either disconnect it and charge directly on the terminals, or the recommended way is to connect the charger to the + and - posts provided in the engine bay.
    Hope this helps but I would be getting a code scan first.
    Andy
  7. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    Dec 2013
    cyprus
    Quote Originally Posted by apole View Post
    Andy
    thanks for ur reply. how i understand it is that on last start of the car, on ignition i observed that All lights on car switched off (was night) and then back on again. this nefore was not happening. Later on driving was like the car was not normal.
    now for the chsrging, if u use the + and - in the front bonnet bay it is sire that there is no any worry to destroy the ecu or somethong? battery must be connected csuse the alarm is activated if u remove it.
    thanks
  8. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    46 Post(s)
    Charge from the points in the bonnet. I've removed the battery in my A6 and the alarm didn't go off??
    You'd be best just buying from Audi.
  9. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    Dec 2013
    cyprus
    hi. yes i tried to remove the battery, i removed it and the alarm was activated. and for this reason I put it it back. why the alarm wss ON without bsttery? is there a back up battery?
    thanks
  10. Re: Audi A6 2.0 TDI 10/2006 c6 change battery
    46 Post(s)
    I assume you're doing this with the doors unlocked? Ie not just opening the boot with the key?
    I suggest having another look at the links I posted as they'll help you alot.
  1. Failed battery? 2006 2.0 tdi
    By STAGMAN in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-11-2013, 04:48 AM
  2. Battery for Audi A6 2006
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-09-2013, 02:52 PM
  3. Please Help Audi A3 2006 TDI 2.0 Battery drain
    By kma01 in forum Chat - Anything with wheels
    Last Post: 23-01-2013, 01:32 PM
  4. 2006 Passat TDI - Buzzing Sound from Battery
    By dogfighter2111 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-12-2010, 05:49 PM
  5. auto 2006 tdi sharan gearbox oil change
    By Capt T in forum Touran - Sharan - Caravelle
    Last Post: 21-08-2009, 07:25 AM
