Thread: Front fog lights- help
Results 1 to 8 of 8
  1. Front fog lights- help
    Apr 2009
    cb99en
    I have just got a 2011 Passat estate se model with front fog lights below the bumper, but how can you turn them on? The light switch has a position for rear fogs but not front ones.
    i have checked the manual and it seems they might come on when going round corners with the indicators on? But can they ever come on as fog lights?
    thanks all
  2. Re: Front fog lights- help
    46 Post(s)
    You'll probably find that they're your Daytime Running Lights.
  3. Re: Front fog lights- help
    Apr 2009
    cb99en
    Is there any way of using them as fog lights?
  4. Re: Front fog lights- help
    46 Post(s)
    I think fogs are a different setup to DRL and you'd need the correct retrofit package including fog housings, coding, wiring and a light switch.
  5. Re: Front fog lights- help
    46 Post(s)
    You'd need this - http://www.kufatec.co.uk/shop/en/ind...=&mobile=false
  6. Re: Front fog lights- help
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    If you have fog lights fitted then I have found that if the switch is set to the headlight position the first pull out switches on the front fogs and the second pull out switches the rear fog.
  7. Re: Front fog lights- help
    Jan 2010
    SE UK
    I'd like the DRL's to stay on with side light setting, anybody know if this is feasible ?
  8. Re: Front fog lights- help
    Wales
    drl only used as daytime alternative lights that can be switched on or off in computer settings on steering wheel.. If you have TWO icons for foglights on your lightswitch that will denote front AND rear fog lights. I also have one icon (rear fog) thats it im afraid unless you upgrade with new switch .. loom and lamp (£200) approx.
  1. All-weather lights instead of front fog lights
    By sijomi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-12-2016, 07:02 PM
  2. Led Lights In Front Light Unit Or Fog Lights???
    By bigbadsexy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-09-2009, 07:28 PM
  3. front fog lights
    By bodie71 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2009, 09:01 PM
  4. front fog lights
    By littlejim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2007, 06:36 PM
  5. Front Fog Lights
    By Davidj241 in forum Passat - Archive Topics
    Last Post: 18-02-2007, 07:19 PM
