Thread: help! fuel pump/speed sensor
  1. help! fuel pump/speed sensor
    Jan 2014
    allanton, scotland
    driving along and car cut out, called aa who diagnosed it to be feul pump/injectors
    took it to arnold clark vw(old verve) and told them same info, they then diagnosed a speed sensor
    on loom? fault(£500) but after fitting new parts they then called back to say the fuel pump
    was also faulty(further£350) anyone know of these two things happening at same time?
    vw uk taking arnold clarks word , where do i stand?
  2. Re: help! fuel pump/speed sensor
    Sep 2008
    SE London
    "Speed sensor" should show up on diagnostics which they would've performed first.
    Ask for your VAS diagnostic's printout -- you've paid for it, it's your property
    You gave them the AA's diagnosis, presumably telling them that's what you wanted
    them to do. But they went and did something else...
  3. Re: help! fuel pump/speed sensor
    Norfolk
    Quote Originally Posted by dougief View Post
    A B6 engine can still run when a speed sensor fails, unlike previous models. Sounds like only the fuel pump was faulty.
  4. Re: help! fuel pump/speed sensor
    Jan 2014
    allanton, scotland
    Quote Originally Posted by martin1810 View Post
    arnold clark wouldnt change theyre stance, got £150 off an £872 bill.
    gutted , its my dads car needless to say wont be back near the place
  5. Re: help! fuel pump/speed sensor
    Apr 2010
    Ashford, Middlesex
    There is a reason that they are known as Arnold Shark......
    Sent from my GT-I9300 using Tapatalk
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
    1 1 0
  6. Re: help! fuel pump/speed sensor
    Sep 2008
    SE London
    And that's proof that they over-charged you. You want all charges associated with the unnecessary changing of speed sensor back.
    Did you pay by credit card? If so, advise your card company immediately. Meantime write to the relevent named director, advising of what's happened, and what you require in terms of re-imbursement. Tell them that "this is an open letter and you reserve the right to produce it if proceedings are necessary".
    Also in the letter say you are asking the AA to nominate an independent technician to confirm their original diagnosis, and failing re-payment of the £x you've paid for the unnecessary speed sensor change, will get that report at a further cost to them. You also want the old speed sensor back for evaluation. That's your property too
    Don't let them get away with it!
  1. Replies: 9
    Last Post: 17-01-2016, 03:08 PM
  2. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
  3. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  4. fuel pump sensor
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-09-2009, 02:03 PM
  5. 2.5 Tdi engine speed sensor for diesel pump
    By adamss24 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-01-2008, 08:12 PM
