Thread: Audi A6 C6 Seat Swap Help
Results 1 to 10 of 12
  1. Audi A6 C6 Seat Swap Help
    Mar 2011
    Cheshire
    Hi Gents
    Apologies if this has been covered before but if anyone can point me in the direction of a guide I would be ever grateful. Im am about to attempt a seat swap in my Audi A6 C6 avant. The new seats come with the rails so am hoping it should be simple. I can find a guide for the C5 having done this on my previous car but nothing for a C6.
    Thanks in advance.
    Matt
  2. Re: Audi A6 C6 Seat Swap Help
    46 Post(s)
    Why are you changing them?
    It should only be a matter of undoing the bolts/screws in each corner of the 2 rails.
  3. Re: Audi A6 C6 Seat Swap Help
    Mar 2011
    Cheshire
    I was hoping that would be the case! Just seeing if anyone had tried and come across anything I should know about or be careful of. The seat belts seem to be joined to the seat, Im hoping they will come off simply too? Im swapping from standard leather seats to S Line. I find the standard seats quite uncomfortable. I find there is not enough support under my legs and at the sides.
  4. Re: Audi A6 C6 Seat Swap Help
    46 Post(s)
    The first part of this should help with seat removal - VW AUDI Forum - VWAF
  5. Re: Audi A6 C6 Seat Swap Help
    Jan 2014
    Bolton
    Seat removal video at this link. Including seatbelt unclipping etc.
    How to Remove the Front Seat - B6/B7 Audi A4 2002-2008 (Wolf Auto Parts) - YouTube
    Hope this helps.
    Nino
  6. Re: Audi A6 C6 Seat Swap Help
    46 Post(s)
    Quote Originally Posted by Nino76 View Post
    Hope this helps.
    Nino
    Thats a A4, might be different.
  7. Re: Audi A6 C6 Seat Swap Help
    Jan 2014
    Bolton
    Apart from the plastic trims on the runners at the start of the video its the same. I used it when i wanted to properly hoover the carpets on mine underneath. Going to have to do mine again tomorrow as I've stripped one of the height gears.
  8. Re: Audi A6 C6 Seat Swap Help
    Jul 2011
    Blandford Forum, UK
    Haven't done this myself but I know if you unplug the air bag circuit and turn the ignition on before both seats air bags are reconnected, the airbag warning light comes on requiring VCDS to reset it. This is easy to do if you take both front seats out and test the electrics having only put one seat back. You've probably got the VCDS equipment anyway?
    A6 allroad 3.0 TDI 2008 / A3 Sportback 2.0 TDI 2007 / A2 1.4i 2001 / Golf Mk6 2.0 TDI 2010
  9. Re: Audi A6 C6 Seat Swap Help
    Jan 2014
    Bolton
    Disconnect the battery. Unplug seats. Do work required. Plug seats back in. Reconnect battery. That way the car wont know.
  10. Re: Audi A6 C6 Seat Swap Help
    New Forest
    80 Post(s)
    If you disconnect the battery, do you then need to enter a radio code? Is it not easier to remove a fuse for the airbags? (same as disconnecting the battery as far as the airbags are concerned?)
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  1. Seat swap
    By neebsta in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-12-2013, 10:21 PM
  2. A6 Seat Swap - Heated Seat Question
    By flippantaudi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-11-2013, 05:05 PM
  3. audi 80 seat swap/dash bulbs/gear linkage
    By xantiaman in forum 80 - 90
    Last Post: 13-07-2009, 08:16 AM
  4. Seat swap .......
    By por911t in forum Jetta MK3 - 2005 - 2013
    Last Post: 24-06-2008, 08:28 PM
  5. Seat swap...........
    By por911t in forum The Commercial Range
    Last Post: 23-06-2008, 08:53 PM
