Thread: braking specifications
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: braking specifications
    Dec 2007
    Launceston, Cornwall
    Hmm.....yes, I’ve wondered about a breaker bar. I guess it’s the combination of the swivel end and the long arm which is supposed to be so effective. But the typical length of 600mm seems a bit short for good leverage. But then again, anything longer would probably not get in there - my 4ft scaffold pole certainly won’t - oh, for a hydraulic lift.........
  2. Re: braking specifications
    Near Blackpool
    48 Post(s)
    Exactly, my scaffolding pole won't fit and I'm sick of it scratching my socket set or my spanners so problem solved and yes I can't convince the other half to let my dig a pit in the drive either! The breaker bar is good you just need to maneuver in it sometimes and also to jack car up as far as you can with you jack sometimes I've put a block of wood under my axle stand and then jacket it again with another block of wood on jack :-) railway sleepers work wonders. Don't trust those little drive on ramps heard too many horror story's of them collapsing.
  3. Re: braking specifications
    mjhamilton Guest
    Has anyone tried the extra jack trick? I have used it in the past
    Put the bar over the head of the bolt with the end a jacks height from the ground
    Put the jack in this gap and start to pump
    I have found the that works in confined spaces and in most cars has provided constant torque which gets the bold started
  4. Re: braking specifications
    Near Blackpool
    48 Post(s)
    Done that too but paranoid of it slipping off as can't keep hand on the end of the bolt.
  5. Re: braking specifications
    Dec 2007
    Ah, got it. Remembered a tip someone suggested - put the wheel on full lock. Tried it, and hey presto, plenty of room to get the scaffold pole on. Slackened one of the caliper carrier bolts easily, just as a trial. Bit short of space in the garage though, so waiting for a dry spell.......
  1. B6 Specifications/Optional Extras
    By mercedeslimos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-10-2011, 12:29 AM
  2. Attention Rear Differential Specifications
    By Quattros in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2010, 01:15 AM
  3. Specifications
    By Volk in forum Bora - 1998 - 2005
    Last Post: 04-02-2008, 07:05 PM
  4. Camber Specifications
    By Silver in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-07-2007, 09:55 AM
  5. Oil specifications.
    By Ricko61 in forum Archive posts
    Last Post: 04-09-2006, 09:52 PM
